fuel filter to fuel rail line replacement
Old Apr 6, 2016 | 09:35 AM
ianD's Avatar
Noticed a nasty kink in the flexible portion of my fuel line that runs from the filter to the fuel rail, it's starting to crack but not all the way through. Anyway, I'd like to replace it before it becomes a problem, called the dealership and the replacement was around 150$. Called the local napa/autozone places but they don't carry a replacement. Anybody know of any other options here? The closest junkyard to me is 45 minutes away and they'll only tell me what vehicles they have there and won't specify what parts are still on them so it's a last resort. 22re 4x4 by the way, thanks
Old Apr 6, 2016 | 09:40 AM
scope103's Avatar
You'd used a junked rubber hose as a fuel line? You're a lot braver than I am.
Think how much more help you'd get if you told us the part number you got from the dealer. Then someone who COULD help you wouldn't have to figure it out on their own.
You didn't provide a year, but I'm going to guess the part you want is 23901-35010.
About $125. http://parts.lakelandtoyota.com/show...rimLevel=18292
OR: you could try a hydraulics shop. For a brake line, they can cut off your fittings and screw them onto new hose. I don't know if this would work for gasoline, but it wouldn't hurt to ask. I also don't know if it would save you any money.
Old Apr 6, 2016 | 10:13 AM
ianD's Avatar
Not like I knew about it, shrugged my shoulders and said "f*** it" and kept using it. I just noticed it and will replace it before I drive it again. The dealer didn't give me a part number, just a price. I tried a local place that makes hydraulic lines, but they only do hydraulic lines, not fuel or brake lines and they couldn't tell me of anyone local that did. I had a brake line made for a motorcycle from an online company where you just told them what banjo fittings you needed and the required length, I was thinking along those lines.
Old Apr 6, 2016 | 11:41 AM
scope103's Avatar
Originally Posted by ianD
... The closest junkyard to me is 45 minutes away ...
Originally Posted by scope103
You'd use a junked rubber hose as a fuel line? You're a lot braver than I am....
Not like I knew about it, shrugged my shoulders and said "f*** it" and kept using it. ...
I meant replacing your current one with one from a junkyard. Pieces made of steel are usually fine, but I'm reluctant to use something that's basically consumable from a junkyard. All Toyota truck parts in junkyards are at least 20 years old; if yours wore out at 20 years how well is the junk one going to fare?
Old Apr 6, 2016 | 12:02 PM
wyoming9's Avatar
Red face
Might be nice to know just what engine Then I might be able to tell you how to fix it
Since the 3.0 Has the filter on the frame I am betting on a 22R series engine.
Once it gets to the point your gas leak is a few gallons a day.
You can cut the metal lines on each end and replace the rubber line with new fuel injection line and fuel injection clamps
Last I bought a 50' Roll I paid $6.00 a Foot
Old Apr 6, 2016 | 12:12 PM
MAINETOY's Avatar
fuel line with banjo fittings
I got one,i sent you a pm.
lbhsbz
Apr 2, 2018 01:13 AM
arlindsay1992
Jan 27, 2016 02:30 AM
dudeinhole
Jan 26, 2016 04:51 AM
Oleyoter87
Jan 25, 2016 08:03 PM
noahstancik
Jan 22, 2016 10:34 PM
