ozzir70's 87 pu build
Old Mar 29, 2016 | 06:19 PM
ozzir70's Avatar
Ok, I am attempting my second build. First one was before I found YT. I'll do my best to keep it updated. Just bought this truck from Grand Rapids and drove it back to Chi town. any input on this build would be awesome.
Old Mar 29, 2016 | 06:34 PM
ozzir70's Avatar
Interior is near mint, frame needs some welding. Truck will get about everything new, already have most parts.
Here is what I have patched so far. The frame was not that bad, I probably went over board with the plating bit i wanted it strong. I still need to replace the bed mounts and the cross member.
Attached Thumbnails ozzir70's 87 pu build-imag0906.jpg   ozzir70's 87 pu build-imag0907.jpg   ozzir70's 87 pu build-imag0908.jpg   ozzir70's 87 pu build-imag0909.jpg
Old Mar 29, 2016 | 07:45 PM
rustED's Avatar
Nice truck! You said you already have most of your parts for the build, what direction are you going with it? Look forward to seeing more!
Old Mar 29, 2016 | 09:42 PM
Terrys87's Avatar
I think you are going to like the extra cab, that little bit of extra room makes a big difference. Looks like you are getting some things done already. Welcome to Yotatech.
Old Mar 30, 2016 | 06:19 AM
ozzir70's Avatar
I'll post some interior pics later tonight. I had an loud engine noise and was trying to figure it out when being an idiot I broke the timing cover. Now I am just rebuilding the whole motor.
For parts i went to LCE and my local NAPA. Hope they are as good as i have read.The LCE stuff. this is what I have so far, new pro torquer cam, rockers and springs, hyper pistons .040 over, new timing cover, oil pump and water pump all new hoses, new radiator.
I will also be replacing the rear proportioning valve with an adjustable one from Summit. Running all new brake lines replacing all brake components.
From Toyota I was able to get both e-brake cables and a new fuel pump hanger. I will be replacing the gas tank as well.
This truck was in fairly decent shape but it will be my daily driver so thats why I may be going a little over board with replacing things. But I want it to be super dependable.
Old Mar 30, 2016 | 06:24 AM
ozzir70's Avatar
rutsED, that is one bad ass looking 4 runner. And to Terrys 87 thanks for the welcome
Old Mar 30, 2016 | 04:08 PM
ozzir70's Avatar
Here is the new bed mounts and the replacement cross member.
I am going to flatbed it.
I bought an old steel trailer 5x8 should work out well. And thats where I got my patch material from!
Attached Thumbnails ozzir70's 87 pu build-4-1d19ed55-883053-800.jpg   ozzir70's 87 pu build-imag0910.jpg   ozzir70's 87 pu build-imag0920.jpg   ozzir70's 87 pu build-imag0921.jpg   ozzir70's 87 pu build-4-45199a79-1189964-800.jpg
Old Mar 30, 2016 | 04:43 PM
ozzir70's Avatar
Some interior pics, excellent condition. I have already pulled the dash and added the evaporator box and wiring I pulled from another parts truck. so this summer will be much cooler!
Attached Thumbnails ozzir70's 87 pu build-imag0997.jpg   ozzir70's 87 pu build-imag0998.jpg   ozzir70's 87 pu build-imag0999.jpg   ozzir70's 87 pu build-imag1000.jpg   ozzir70's 87 pu build-imag1001.jpg
Old Mar 30, 2016 | 05:30 PM
ozzir70's Avatar
I hope some of the more experienced people on here will give me some input.
I really want to do a dual t-case setup but I am not sure if I am wasting my time doing this and sticking with the IFS. I had planned on the OME toyota lift with HD torsion bars.
Old Mar 30, 2016 | 05:40 PM
ozzir70's Avatar
Old Mar 31, 2016 | 06:17 PM
ozzir70's Avatar
primer and paint.
Attached Thumbnails ozzir70's 87 pu build-4-03feba19-1017977-800.jpg   ozzir70's 87 pu build-4-1e99e00d-1238111-800.jpg
Old Apr 1, 2016 | 05:07 PM
ozzir70's Avatar
Here is the new tank mounted. I also replaced the OE Toyota filter with a GM quick disconnect. I couldn't get the plastic line to stay where I wanted it so I made a sleeve out of an alloy tube to keep it the shape I needed. The line to the fuel rail is a Russell with an adapter from An to 14mm at the fuel rail. So in the future it should be cheaper and easier to change.
and a pic of the completed motor
Attached Thumbnails ozzir70's 87 pu build-imag0953.jpg   ozzir70's 87 pu build-imag0956.jpg   ozzir70's 87 pu build-imag0958.jpg   ozzir70's 87 pu build-imag0936.jpg
Old Apr 2, 2016 | 12:48 AM
rustED's Avatar
Your making some great progress! Your interior looks really nice, you even have the double decker center console/armrest, I'd like to find one of those for mine! Engine looks great too!
Old Apr 2, 2016 | 06:56 AM
ozzir70's Avatar
Easy to make progress when you work for a shop. I'm a service writer for a local shop. So I have a complete shop at my disposal. Makes things a little easier!
Old Apr 5, 2016 | 06:04 PM
ozzir70's Avatar
Motor Is in. And the bumper I have been working on from a piece of 3x6 tubing
Attached Thumbnails ozzir70's 87 pu build-imag0940.jpg   ozzir70's 87 pu build-imag0942.jpg   ozzir70's 87 pu build-imag0950.jpg   ozzir70's 87 pu build-imag0947.jpg   ozzir70's 87 pu build-imag0959.jpg
Old Apr 5, 2016 | 06:11 PM
ozzir70's Avatar
Flatbed mounted and fuel tank hooked up. I wanted to recess the fill. No real reason just thought it would be cool. Also got the front brakes done
Attached Thumbnails ozzir70's 87 pu build-imag0961.jpg   ozzir70's 87 pu build-imag0962.jpg   ozzir70's 87 pu build-imag0960.jpg   ozzir70's 87 pu build-imag0932.jpg
Old Aug 14, 2017 | 08:19 AM
coryc85's Avatar
Finally found your build thread. Very nice work on that engine, and I really like that rear bumper. Must be nice to have all that equipment at your disposal.
Old Aug 14, 2017 | 08:25 AM
ozzir70's Avatar
Thanks Cory. I have done a ton more work but most of the pics are on my laptop that crashed. I will be updating as soon as I can. And yes having a complete shop to use is very helpful
Old Aug 15, 2017 | 03:30 PM
ozzir70's Avatar
I was able to find some pics of when I pulled the interior and sound proofed the cab. I think I did this back in April
Attached Thumbnails ozzir70's 87 pu build-img_20170318_112743586.jpg   ozzir70's 87 pu build-img_20170318_112749554.jpg   ozzir70's 87 pu build-img_20170318_112806831.jpg   ozzir70's 87 pu build-img_20170318_112815444.jpg
Old Aug 15, 2017 | 03:35 PM
ozzir70's Avatar
I cut the material into strips to fill in between the ridges in the floor. Then put a second layer over it. It took a long time to get the foil smoothed over
Attached Thumbnails ozzir70's 87 pu build-img_20170318_150043868.jpg   ozzir70's 87 pu build-img_20170318_150052879.jpg   ozzir70's 87 pu build-img_20170318_153712836.jpg
