Windshield wipers come on when going through water
A problem well-stated is a problem almost solved.
What model escalade are you working with?
If first-gen 4Runner, inspect the wiper control relay in right side kick panel behind / above the ECU. Water from splashes may come into the cab through the opening in bulkhead for radio antenna if opening / grommet is not sealed well. A leak around windshield pinch weld may also cause water to drip there.
OBT
Mar 31, 2016 07:40 AM
