Working on transforming my 86 4rnr
Old Feb 20, 2016 | 07:02 PM
bigmumbles69's Avatar
ok I've read quite a few threads on here
I'm having some difficulties after rebuilding my engine cause the engine was completely wore out. What I have done to it so far I've deleted egr and idle up control since I have removed my ac. I have iac plugged in since I'm not wanting a check engine light on. I have lce headers bored 30 over deck and timing cover shaved 010, and mild torquer cam all this done I've went through put it all back together.
I did cam break in truck idle was a little off that made it difficult so I changed tps and truck idled better but after break in for the cam was done and truck cooled off it had issues starting up and would not stay idling. I had to keep on the throttle to keep it running to get it home and few days later checked timing on it with timing light ran great idled fine after it cooled off tried to drive it again and it had issues starting, got it to start and it ran like crap stalled out and now it cranks but will not start. I did find a fuel leak at the fuel damper but I don't know why it will not crank if anyone can help it would be great.
Old Feb 21, 2016 | 01:07 PM
ok another question how does the blip test work for the obd 1 22re so i can see cause since cam break in the cel has came on now
Old Feb 21, 2016 | 01:19 PM
92ehatch's Avatar
Your first post is very hard to read with no punctuation. It's a whole lot of incoherent mess.
As far as checking the codes.
Old Feb 21, 2016 | 01:42 PM
ok thanx 92ehatch for the help. as far as you said i added some punctuatoin and read it back to my self to make sure it read ok
Old Feb 23, 2016 | 12:43 PM
Kean's Avatar
Originally Posted by bigmumbles69
....as far as you said i added some punctuatoin and read it back to my self to make sure it read ok
fyi... It didn't work. Maybe the edit didn't save properly?
punc·tu·a·tion
ˌpəNG(k)(t)SHəˈwāSH(ə)n/
noun
1.
the marks, such as period, comma, and parentheses, used in writing to separate sentences and their elements and to clarify meaning.
Old Feb 25, 2016 | 09:59 AM
kcaudill's Avatar
Holy run on sentence batman
Old Feb 25, 2016 | 10:01 AM
mxchamp5's Avatar
G
daM
Old Feb 25, 2016 | 10:20 AM
Terrys87's Avatar
I cleared some of the punctuation up. Are you getting plenty of fuel. I pull the line off of the back of the fuel rail and with the fuel bypass jumper in, I see if I get about a quart of fuel in a minute or so. Not a test suggested by Toyota but close enough for me to see if I am getting plenty of fuel.
Old Feb 26, 2016 | 04:26 PM
ok thanx Terrys87 iwill look into that. I haven't been able to work on it during the week due to work, but plan on spending sometime tommorow on it. Another question i have does anybody know, if the IAC has to connected to the vacuum lines and connected to the coolant lines for the truck to run properly
Old Feb 26, 2016 | 04:42 PM
millball's Avatar
Toyota didn't put it there just to annoy you.
It may be that the truck will run without it, but will it run well, No.
Old Feb 26, 2016 | 06:18 PM
92ehatch's Avatar
The aux air valve or iac is there to raise the idle when cold. Is it necessary for the truck to run. ..no
If you are in a cold climate, removing it would not be beneficial.
In a warmer climate you could get away with it.
But like with anything else, probably better to ensure is working as designed.
Old Feb 28, 2016 | 11:47 PM
Terrys87's Avatar
Been a while since I worked on the IAC, but if I recall right, I just pulled it and put it in the freezer for an hour and then see if the valve is operating like it should.
Old Feb 29, 2016 | 08:05 AM
92ehatch's Avatar
Here is the proper test procedure and adjustment for the aux air valve.
I used a hair dryer and freezer to ensure my bi metal functioned properly. Then after letting it sit to room temp 68 degrees i adjusted it.
sanctfy
All Other Toyota Swaps
18
Sep 4, 2025 07:30 PM
sanctfy
Nov 2, 2016 04:39 AM
Davebarbier
Dec 19, 2015 06:27 PM
