Timing help!!
Old Feb 10, 2016 | 04:38 PM
4by4yoter's Avatar
Timing help!!
the toyota is almost alive but I've read i have to jump power between this connecter to reset the computers timing. My question is do i jump the connecter then turn the ignition on then set it to the correct timing or would i leave the connecter jumped while i try to start the vehicle again
Old Feb 10, 2016 | 06:17 PM
voiddweller's Avatar
This is all I got
Old Feb 10, 2016 | 06:34 PM
d-wood's Avatar
On my 1993 22re I did it while my engine was running.that is if your talking about timing it. It's the t and e2 by the fuse box.
Old Feb 10, 2016 | 07:19 PM
4by4yoter's Avatar
Its alive but i was missing a oil sensor in the block! Time to go buy more oil but shes finally running!
Old Feb 11, 2016 | 12:53 PM
nv4runner's Avatar
You can connect the terminals at any time. The manual you are referencing has the engine running when you connect the T and E terminals. Make sure you do plug off the engine side of the hose if you have a vacuum mechanism on your distributor. Prevents a vacuum leak and gives you base timing before the vacuum actuator does its job. Otherwise your timing will be way off.
Old Feb 11, 2016 | 01:09 PM
4by4yoter's Avatar
thanks guy got it running pretty good. Just have to fix some coolant leaks and bleed the clutch again as it peaked as well :/ is there an o ring or washer that goes to the metal coolant pipes the connect to the back of the timing cover? Im just going to rtv it in an attempt to fix the leaks
Old Feb 11, 2016 | 01:33 PM
I'd recommend getting the fsm and fixing the leaks with the right gaskets, etc
Old Feb 11, 2016 | 01:37 PM
4by4yoter's Avatar
What gaskets? You have a part number? They have the standard gasket from the timing cover on them but they still leak
4by4yoter's Avatar
and whats fsm
Old Feb 11, 2016 | 02:28 PM
Fsm is the Factory service manual, all the info you could need for repair
Old Feb 11, 2016 | 02:44 PM
scope103's Avatar
You'll get a lot more useful help if you can FIRST figure out what your vehicle is.
I'm going to surmise it's a Toyota, but beyond that you're making us all guess. Year? Model? ENGINE?
There are two gaskets behind the timing cover of a 22re. http://www.toyotapartsoverstock.com/...rimLevel=18292
http://web.archive.org/web/201210231.../8timingch.pdf
IF that's the engine you have.
Old Feb 11, 2016 | 03:24 PM
4by4yoter's Avatar
86 toyota sr5 efi 22re. Im referring to the coolant pipes that connect to backside of the timing cover. One on the drivers side, the other on the passenger side. My question is do they have o rings or washers to seal them if so please provide the part number or a link. I bought this truck with a blown up engine. I bought a used block and bought a brand new head. I put this entire thing together without ever taking a look at a manual. It runs great and doesnt leak a drop of oil the only thing it leaks is coolant. The links you provided did not help to answer my question thanks though.
Old Feb 11, 2016 | 04:03 PM
4by4yoter's Avatar
THIS IS WHERE IM LEAKING FROM IF ANYONE HAS THE PART NUMBER FOR AN O RING OR GASKET FOR EITHER OF THESE TUBES ITS MUCH APPRECIATED
Old Feb 11, 2016 | 05:07 PM
scope103's Avatar
The first picture looks like the heater water outlet pipe, and the second like the No 1 water bypass pipe.
The first link I provided shows that the timing cover gasket extends to gasket those two connections:
Your second photo looks like there might be a gasket; I can't tell from the first. Did you use that gasket?
The first link I provided shows no other sealing surface.
Old Feb 11, 2016 | 06:41 PM
4by4yoter's Avatar
Both gaskets are there and brand new. Both leak
Old Feb 12, 2016 | 09:05 PM
4by4yoter's Avatar
Fixed with ultra black. One more leak to track down. Hoping its just the thermostat seal but if not ill be replacing the intake manifold gasket AGAIN. Oh well
Old Feb 13, 2016 | 05:29 AM
92ehatch's Avatar
Could be the pipe that's under the intake manifold
Old Feb 13, 2016 | 09:40 AM
4by4yoter's Avatar
nah its pooling on the top of the intake. Hoping it was just leaking from the thermostat house as the old thermostat seal was crap. If not, time to replace intake gasket again. Not a huge deal i gues since i have the motor mostly taken back apart.
Old Feb 13, 2016 | 08:32 PM
4by4yoter's Avatar
Sold it. Fixed the coolant leak then it started pouring out of the timing cover. 22re is the most finicky motor ive ever dealt with.
Johnsoline
Dec 31, 2015 08:35 AM
Patricia Ringo
Dec 15, 2015 10:53 AM
Andy A
Dec 12, 2015 02:08 PM
PureTacoma_Tundra
PureTacoma_Tundra
Dec 8, 2015 09:20 AM
