1985 22re fuelpump
Old Jan 11, 2016 | 01:38 PM
steve miller's Avatar
1985 22re fuelpump
does the fuel pump on a 1985 22re have voltage when the key is on or when starting ?
Old Jan 17, 2016 | 07:47 AM
raevenzero's Avatar
I believe the 22re has voltage while cranking and once the AFM flapper opens. It does not have power by simple placing the key in the in position.
Old Jan 18, 2016 | 06:35 AM
reelal's Avatar
I'm old and retired but if I remember right when you turn the ign key to the on position the pump will get power for about 1.5 seconds unless you continue to the crank position.
If the engine doesn't run the pump will stop.
Old Jan 18, 2016 | 10:35 AM
with full battery voltage, key in on position-no voltage to pump. key to start position and cranking, no more than 10 volts. anyone know if this is normal??
Old Jan 18, 2016 | 02:40 PM
thasnake04's Avatar
check your relay that sits by your ecu in the passenger firewall, take the cover off and see if its clicking properly , you should be able to hear the fuel pump pumping fuel when you put key in the on position
Old Jan 18, 2016 | 05:58 PM
no fuel relay there, only a wiper relay
Old Jan 18, 2016 | 10:30 PM
Terrys87's Avatar
If I recall right, you should be able to hear it for a few seconds when you first turn the key on. Be at the tank and have some one to turn the key and you should hear something at first and then it will stop.
Some other information that might help you.
Here is the location of the Circuit Opening Relay. Best to get it from behind the passenger speaker. Operates fuel pump in tank.
Circuit Open Relay
Codes... http://4crawler.com/4x4/CheapTricks/...es/index.shtml
How to get Check Engine Codes. I just put this up for others. Applies to 87 and up. 86 and older is the bottom picture. TE1/E1
The Diagnostic port for the 85-86 is on the Drivers side inner fender and is nothing the same as the 87 and up. Here is T1 and E1 jumped. The codes and engine flashes are the same as the rest of the trucks on the dash.
Codes...http://4crawler.com/4x4/CheapTricks/...es/index.shtml
http://www.youtube.com/watch?v=9qEQM...ature=youtu.be
Here is how you do a Fuel Pump Bypass on the 85/86.
Jumper wire the Yellow Plug on Drivers side. ( Jumper wire should be in both contacts for testing, I just didnt have it in for picture purposes and mostly a referece for me at a later time.)
Fp +B Fuel Pump Test for 87 and newer. Use a paper clip for better results.
Old Jan 19, 2016 | 04:45 AM
thanks for all the info. I will remove speaker and examine relay. my error codes flash when key is on. do I still need to put in jumper?
84 yota dude
3.4 Swaps
Jun 11, 2016 09:44 PM
yoterr
Jan 11, 2016 04:14 PM
TSchroed189
Jan 11, 2016 04:13 PM
cdreever
Jan 10, 2016 06:28 PM
Yotapower01
Jan 10, 2016 01:30 AM
