Rear heater removal and bypass
Old Jan 1, 2016 | 06:20 AM
cwm's Avatar
cwm
Does the complete disconnection and removal of the rear heater throw any codes on the system? To me it just takes up space. Also, does anyone have good pics as where to bypass the rear heter completely from the engine bay so I can remove unnecessary rustable metal bits? I found plenty of threads but no photos. No need for a heater in the south. Thanks.
Old Jan 1, 2016 | 08:36 AM
DRCOFFEE's Avatar
Disconnect the rear heater up in the engine bay firewall. Just unplug the two hoses connected to the rear lines and use a barb connector pipe to connect the hoses together. Very simple to do
Old Jan 2, 2016 | 11:42 AM
cwm's Avatar
cwm
Exactly what I ended up doing, thank you. I was getting stressed about the coolant going everywhere and overthought the problem.
Old Jan 2, 2016 | 02:10 PM
vasinvictor's Avatar
You'll want to get a new console that doesn't have the blower in it, to make use of your new space.
Old Jan 3, 2016 | 07:16 AM
cwm's Avatar
cwm
Not necessary, but it would close some gaps now there. A small sheet metal riser bolted to the blower is what the console mounts on, so I just took it off and mounted it without the heater parts.
Attached Thumbnails Rear heater removal and bypass-image.jpeg   Rear heater removal and bypass-image.jpg
Old Aug 15, 2018 | 07:22 PM
maguirre's Avatar
Hi CWM... I have to do the same thing on my 2000 4Runner. I rear lines are leaking. Do you have a pic of your pipes bypassed?
Old Aug 18, 2018 | 06:13 AM
Malcolm99's Avatar
That is some invasive surgery to remove that rear heater and blower for extra space, most just replace the line with rubber or copper and reconnect, alot easier that making room under the passenger seat for garbage to hide.
Old Aug 18, 2018 | 08:39 AM
habanero's Avatar
We keep seeing pretty, shiny lines on the 01-02 4runners at the junkyards...my husband replaced his 99's rusty ones with a set of them.
jaaydee
Dec 7, 2015 06:46 PM
Obmi
Nov 27, 2015 03:13 AM
Mms1361
Nov 21, 2015 02:51 PM
Brendan
Nov 12, 2015 08:17 PM
mysteryfish
Nov 9, 2015 01:11 PM
