1989 22re new timing chain 7000 miles died
new timing chain, timing cover on 1989 truck 22re died while driving around ,a little backfire than engine light turns on. turns over but rotor does not move. work was done by a Toyota mechanic on the side. any ideas on what may have happened ?
Ok you need to pull the valve cover off or you may be able to pull out the distributor and shine a light and make sure the chain is still on. Your chain may have come off or cam sprocket/gear .There is a roll pin in the dist gear. maybe it failed . Also did yaw replace the timing guides and tensioner too?
i was in a honda civic that broke something in the distributor drive area, the tow bill was over $900, even with aaa long distance coverage :0
i therefore want to always carry a spare distributor for my 22re...
please keep us posted on what the problem was.
junder28
25
Jun 21, 2016 06:24 PM
