Brake issue Help
Old Aug 27, 2015 | 07:34 AM
87toy pickup's Avatar
Brake issue Help
OK I'm new to Toyotas but always wanted an older Toyota so I recently found a clean 87 Toyota pickup with a 22r 5spd 4x4. It had no brakes and the previous owner puton a new master cylinder (mc) but didn't bench bleed it. So I tired bleeding it on the truck got good clean clear fluid no air and then bleed the rest of the system going from the DSR to PSR to PSF to DSF back to the LSPV got good clean fluid and did that until no more air and I used a vaccum bleeder tried to use the brakes still nothing ck for leaks all lines are good. I can pump the pedal about 15-20 times and start building pressure but then I loose pressure and pedal goes to the floor if I build pressure then start the truck the pedal goes to the floor and won't build any pressure I'm thinking it's the mc but not sure any help is appreciated thank you
Old Aug 27, 2015 | 07:54 AM
wyoming9's Avatar
Red face
Sounds like your still getting air in the lines.
Then the rear brakes could be so far out of adjustment along with the getting air in.
Your not far away if your really stuck I don`t mind helping.
Sometimes people get the calipers on upside down making it impossible to bleed
Bleeder valves do go bad and allow air in.
Old Aug 28, 2015 | 03:58 AM
AKHeathen's Avatar
i crack the lines at the mc and let it flow till it bleeds there, then gravity bleed the rears, then the fronts. it might take a lot of fluid to get the bubbles past, but running a bunch of fluid through it first, then pressure bleed like normal. do the rears first on the pressure bleed. then finish up by cracking the bleed screws and closing on front and rear with no pressure. extra precaution, sometimes you get the proportion valve pressured after a bleed and it won't work right. not often, but i've seen it enough to always do it.
Old Aug 28, 2015 | 04:59 AM
Marsheen's Avatar
I bought my 94 3vze, and it had a aftermarket brand new master, from Autozone I think. It went out on me shortly after I bought it. Put a brand new one on and my problem disappeared. Same thing happened to my clutch. DON'T BUY MASTERS FROM AUTOZONE.
Old Aug 28, 2015 | 05:13 AM
AKHeathen's Avatar
nope, and orileys hasn't been good for products coming out of csk either, which used to be at least 50% good. i buy carquest or napa or online now.
Old Aug 28, 2015 | 06:24 AM
Terrys87's Avatar
You can buy an Aisin online for about the same price as parts stores. I have not had much luck on clutch or brakes cylinders from parts stores.
Also Toyota used different sized cylinders for the same generation. Pay attention to which one you have.
Old Aug 28, 2015 | 08:04 AM
wyoming9's Avatar
Red face
Funny thing I never have bleed but my first Master Cylinder so long ago
Then after my first failed attempt and very expensive did I ever touch a LSPV unless to remove it
With the amount of parts coming from China It is hard to get quality .
More and More I am going to my dealer.
Old Aug 28, 2015 | 08:21 AM
Odin's Avatar
This works.
or Oreillys, Advance, ect.
Go ahead and include clutch masters and slave cylinders to that list.
Got that right
Old Aug 28, 2015 | 02:30 PM
Marsheen's Avatar
What could happen if you put the wrong ones on?
Old Aug 28, 2015 | 03:48 PM
Terrys87's Avatar
What happedned to me is I put the smaller one on when I should of used the larger one. I was unaware of that Toyota used both styles. When I had the wrong one on, the piston popped out and I lost brakes. Luckily there were was no traffic at the bottom of the hill and I was able to blow thru the stop sign. It was an exciting time to say the least, but could of been a bad situation. It is posted in my 86 runner build somewhere in my link below.
My 88 runner uses the smaller cylinder but my 85 and 86 uses the larger one. Toyota does some screwy stuff. I just bought an AC drier and depending on which month of 88 determines which drier you use.
When you do get new parts, always compare what you get to what you have. I too have been getting more parts from Toyota or OEM dealers online. Ebay, Amazon, Rockauto.. are just some of the other sources I use.
Here is what happened. I lost all brakes at once. Drivers side leaked and I just changed it only. From now I compare to the oppisite side if swapping parts.
The piston would not stay in.
The one on the right is what I should of had all along.
Old Aug 28, 2015 | 08:01 PM
AKHeathen's Avatar
if that ever happens, pump the brakes, you will get the other set working. i took mine on a road test to get things all broke back in after a year and a half of sitting and did a hard brake test getting off the highway. almost locked them up when the rear brake line ruptured over the gas tank. just pumped it a few times and drove home on front brakes. the fluid is devided in the resivior for this reason. that was a couple years ago and i just recently got around to fixing it, lol.
Old Aug 29, 2015 | 06:25 AM
wyoming9's Avatar
Red face
Just what were you driving ??
It sure did not have a stock Toyota Reservoir or master cylinder
Now the old Domestic vehicles had a split system.
Old Aug 29, 2015 | 10:14 AM
Terrys87's Avatar
The disadvantage of a single reservior is the loss of all fluid. Surprised that Toyota has not done the dual tank.
Old Aug 29, 2015 | 10:41 AM
wyoming9's Avatar
Red face
In theory you should have enough brake pressure to get the vehicle stopped
Then it could be if they had the complete split system some one would no doubt keep driving till that system failed at which time it would be Toyota`s fault By the time the Lawyers got done twisting the facts
Looking at a Master Cylinder off a Mid Eighties truck it would not take much work to enable one to run a dual reservoir giving you a true split system
Old Aug 30, 2015 | 06:02 AM
AKHeathen's Avatar
1990 4runner. as i said, it went years just on front brake fluid. it may be one chamber, but certainly does have a low-level devider in it. fairly sure it's been a government requirement for 30-50 years or more.
Old Aug 30, 2015 | 06:07 AM
AKHeathen's Avatar
just took a stroll out to my 86 2wd, and it too has a low level radial divider in the soda-can resivior. pulled the screen and probed it. iirc, same one on my 84
Old Aug 30, 2015 | 06:08 AM
AKHeathen's Avatar
go out and probe yours if you don't belive me.
Old Aug 30, 2015 | 10:42 AM
wyoming9's Avatar
Red face
Mine does not have any brand new never been used!!
Old Aug 30, 2015 | 04:30 PM
Okay so I pulled the rear brakes found on Wheel cylinder leaking changed i t and the shoes adjusted the rear brakes to the point that they were draging slightly rebleed the system still no brakes also noticed were the mc and booster meet a slight leak which makes sense since when I press the brakes while truck is running the engine studders and pedal has no resistance/bearing force just goes to the floor I might try buying another LSPV or buy a manual one from summit also I have gone through about 1 1/2 quarts of brake fluid
Old Aug 30, 2015 | 11:26 PM
wyoming9's Avatar
Red face
It is still possible you have a connection drawing in air.
It is possible in the course of the last owner messing with the master cylinder some how the length of the push rod some how got out of adjustment .
Since you say you have a gap between the booster and the Master Cylinder this could very well be the problem
Even with air being drawn in pressure should build when the pedal is pumped it just won`t hold very long.
It is also possible you got the wrong or a defective Master cylinder out of the box as of late it seems to happen all to often
