Lower your truck for free?
You can remove leaves from the spring packs until the truck lays down on the bump stops.
Then. if you want the truck to be lower still, you can shorten , or remove the bump stops altogether.
Eventually, the truck will be laying on the tires in the fender wells.
Consult the Lowrider clubs in your area for further info.
I guess it is possible but if I wanted to lower mine, I would look into doing it the correct way. You are asking for problems when going about it the wrong way. Seen some heat springs up with torches and no way would I go about doing that.
I'm assuming 2wd? Toyotaminis is a good place to look at lowered setups. I believe some common ways are to use a lowering block or to reconfigure the leaf pack (either remove leaf or even flipping some over).
voiddweller
19
May 2, 2016 09:10 PM
87blyota
Jul 1, 2015 05:26 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
