O2 Sensor Questions
Old Aug 5, 2015 | 11:12 AM
yipyip45's Avatar
O2 Sensor Questions
I have a 1995 Toyota pickup throwing code 27, for one of the two O2's Truck only has one because it is non california emissions, first question, would it make my truck skip and occasionally backfire? and is it the downstream or upstream O2 if its non cali?
Old Aug 5, 2015 | 01:54 PM
yipyip45's Avatar
found out it is the upstream, but what would be making a 22re skip besides fuel components?
Old Aug 5, 2015 | 01:56 PM
grumpin's Avatar
By "skip", do you mean miss? Backfiring sounds like timing or valve adjustment.
Old Aug 5, 2015 | 02:07 PM
yipyip45's Avatar
it levels to speed and misfires to the point I have to shift down and let off and try to shift up again. I'm thinking injectors.
Old Aug 5, 2015 | 02:41 PM
scope103's Avatar
Start with the easy stuff: check your ignition timing. Then plug gap.
And pull the EFI fuse (to reset the codes), and then when the CEL comes on re-read the codes. As you point out, if you don't have a Calif. ECU you shouldn't be able to get a 27.
Old Aug 5, 2015 | 02:54 PM
yipyip45's Avatar
Thanks I will pull the fuse tomorrow, I ordered a new O2 and am going to change it tomorrow also and I will see if anything changes. This truck was just rebuilt has 1,000 miles. timing went and destroyed the case and was rebuilt from bottom up.
Old Aug 5, 2015 | 10:30 PM
wyoming9's Avatar
Red face
If the engine was just rebuilt I can only hope all the tune up parts are brand new.
Did a spark plug wire that was not seated correct come off or burn off??
Burn off against the manifold.
Maybe rings not seating has caused a plug to foul out??
Old Aug 6, 2015 | 05:47 AM
yipyip45's Avatar
all new plugs and rewired, The motor is practically brand new besides the block. I think it has to do with fuel either a clog or problem with flow or something to do with vacuum system. It seems to be a bunch of little things making a big problem
Old Dec 2, 2015 | 08:16 PM
iammtheking's Avatar
did you ever figure out the o2 sensor issue? I'm currently having the same problem and have a non california model. i am getting codes 21 and 27, i changed the o2 sensor and the code is still on.
krimsonone
Sep 13, 2024 09:33 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Gevo
Jul 29, 2015 11:15 AM
nonstop
Jul 24, 2015 06:29 PM
88yodabasket
Jul 13, 2015 01:32 PM
