Coolant going into reservoir--engine getting hot
85 4runner 22re automatic
The last couple of days, the coolant in my 4runner drains into the reservoir and then pours out the overflow hose leaving the fins exposed in the radiator. I replaced the thermostat recently with a genuine Toyota and I ordered a new radiator cap from Toyota....hopefully that will fix the problem. Any thoughts?
Some other things to consider:
* No white smoke
* No power loss
* Oil looks good--no white gunk on the threads of the cap
* Heater works great
* I tried burping the system but coolant spills out the radiator as soon as it gets to operating temperature so I can't squeeze the upper radiator hose for too long.
* Reservoir cap is a little loose...could that cause a problem?
* Engine temp gauge gets a little high (not to red line but right below) and then goes down to normal after a few minutes of driving. Does this mean the coolant is getting pumped back into the radiator from the reservoir?
* Possibly a bad water pump?
Thanks for any suggestions. I'll post back regarding the radiator cap and if that helps any.
Thanks,
JARED
* No white smoke
* No power loss
Thanks,
JARED
Had this same problem a few years back, was bad head gasket. Was a small hole between the cylinder wall and one of the coolant passages right next to it. For whatever reason I wasn't getting coolant coming back into the cylinder, but when running it was pushing gasses into the cooling system.
Hopefully this isn't it but it's something to put on your "to check" list. Maybe something like a leak down test with the rad cap off to watch for bubbles and/or coolant overflowing.
Good luck.
Good luck.
Good luck.
Good luck.
something sure sounds weird tho.
really good idea to replace the cap.
don't like the temp gauge reading, did it do that with the previous engine?
i think that you can get a test kit that checks for exhaust gasses in the cooling system.
was it overfilled to begin with? you want to leave room for air in the radiator.
the right thermostat is supposed to be the one with two holes in it??
i think that the coolant is supposed to get sucked back into the radiator as the engine cools off, so the radiator cap plays a role in that.
Here's hoping it's the cap. Would definitely change that first.
My head gasket leak was a weird one, I wasn't getting any coolant or oil in the combustion chamber and I wasn't mixing oil and coolant, was just getting combustion gasses in the cooling system. Mine would suck some of the coolant back out of the reservoir when it cooled down, but not nearly enough. That was my oddball/non-standard HG failure.
Simple/cheap fixes first, because 90% of the time that's what it is.
When mine started acting up ( Wife came home saying the truck sounded like a coffee percolator) I know bad thing were coming. this was around 2000. I put some copper seal up in the radiator and it ran ok for about 15 years. Now its really bad, truck sounds like a lawnmower ,7psi on cylinder 3. So now it head gasket time. Oil is clean and sous not use radiator fluid but does blow it out like your having. for a long time i put a 2ltr soda bottle on the over flow hose and once in a while I would pore it back in.
Update on this issue. So I took the 4runner to a mechanic (reputable) and he did a compression test. aside from the #2 cylinder having tight valves and a clogged radiator, he said the compression was good and to have the radiator cleaned out and I should be good.
So I set the valve clearance (sure enough #2 was way too tight) and that helped with the erratic idle. It runs smooth now. I also got my radiator professionally cleaned. Slapped it all back together and the coolant is still not flowing back from the overflow tank and it is going onto the ground.
I did more searching and found that the iiav hose was leaking and had a crack. Replaced that with a new one. I ran a radiator compression check. it held at 14psi for 15 minutes without issue. Then I read online to check the coolant reservoir cap to make sure it is not on backwards. It was backwards and I fixed that. Not sure why that would matter.
After doing all this, today I drove it and it does not overheat and coolant does not spill out but the temp gauge reads about 3/4 high right after restarting it from normal operating temperature and then after driving a mile or so, the temp goes back to normal. Again, the gauge does not hit red.
I bought a new water pump....was thinking that could help but I havent installed it yet for fear that if I have to redo the headgasket, I would be taking the water pump off.
So, I know the majority of these overheating issues....most people point to the headgasket and I would replace this if I knew for sure this was it. But I am not seeing any symptoms of a bl0wn headgasket and a mechanic has said the same thing. Should I try blockchek just to be sure? Anybody use this?
http://www.blockchek.com/
Thanks again. I hope to nail this down soon.
did you put in the two-way toyota thermostat that's supposed to stop the brief hot temp? i put one in my 22re just a few weeks ago, the old thermostat was stuck open.
Hey OSV. I put in a genuine Toyota thermostat (from dealership) but I don't know if it is 2-way? Is there a part # I can reference? Our dealership parts dept has a habit of getting me the right part for the wrong year and I wonder if maybe this is a later model thermostat.
Thanks,
JARED
Thanks,
JARED
Mine was doing the same thing. I did the cap and thermostat from Toyota. Put a new radiator in I had laying around. Then finally couldn't keep it cool at all. Compression was good and oil was good sometimes it just goes. Sucks. Hope it's not a gasket but prepare for the worst and that way you you don't get blindsided.
i still have the box laying around, it's a 90916-03070, here is a relevant thread: https://www.yotatech.com/forums/f116...issues-132015/
sounds like the only problem left is the brief temp overshoot? nothing else is wrong?
SOLVED -- I Think
So after nearly getting the HG kit for this, my dad told me to replace my thermostat. I thought this wasn't going to work as I had bought a Toyota one 6 months prior. Sure enough, replacing the thermostat did the trick. Toyota graciously provided a new one at no cost.
I haven't driven in 4x4 yet, but the temp stays consistently at 1/3 and coolant no longer boils out of the reservoir. Pretty happy camper at the moment.
Longbed 90
Mar 11, 2019 12:38 PM
runnermedic
13
Sep 21, 2015 05:20 PM
LotOMiles
Sep 14, 2015 11:45 PM
