Needing to replace front leaf springs
Im wanting to replace my front leaf springs on my 1994 Toyota 4x4 straight axle they're 47'' inches long by 3 1/2 inches wide .Where would the best place to get a set? Can I use 2wd leafs springs or do i have to use 4x4 leaf springs?
i think that i'm running toyota rears up front, which is ~46" long at ride height, measured straight across, so it's probably about the same length as yours.
however, i think that my springs are only 2.5" inches wide, so if you are at 3.5" wide, is that a toyota spring setup?
maybe it's chevy springs, so a trip to the chevy truck junkyard is in order?
Be nice to know just what they came off.
I am guessing you did not do the SAS .
Do you want to go with new springs ??
A set of used springs of unknown vintage??
I did used springs long ago one was good the other once installed with weight was flat .
Off the vehicle they both looked the same.
General Spring hasa great web site for leaf spring dimensions
dirtrider0129
10
Jun 24, 2015 12:24 PM
TheManOutside
Jun 18, 2015 03:32 PM
