Fuel and spark but no fire
Old Mar 28, 2015 | 04:38 AM
noflyzone's Avatar
#4 cylinder not firing. 86 22re. Rebuild using engnbldr head and kit. Rebuilt spark plugs from Mr. injector. TPS adjusted to spec. Timing set to 5 degrees jumped. I see spark and wet spark plug. I hear fuel injector ticking with stethoscope.
Compression test next. I just don't have the right fitting for this head.
Any other ideas?
Old Mar 28, 2015 | 06:48 AM
Terrys87's Avatar
I have seen a coil send spark to the plugs and still not fire. I suspect the fire is just to weak. I would check the Primary and Secondary on the coil. Haynes Manual has a good check for the coil.
Old Mar 29, 2015 | 07:03 AM
noflyzone's Avatar
Can't believe it ran at all. Wires were 1-2-3-4 instead of 1-3-4-2. Timing was 180 out.
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Doug4320
Mar 24, 2018 10:11 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Sandman
Jul 14, 2015 12:36 PM
