1993 toyota 2wd 22re??? ignition?
I have a yellow wire that comes off same harness as my alternater wire and plug on a 1995 Toyota truck 2wd 22re. does anyone know where this wire attaches. it has a eylet for a bolt to go through. I attached to block but the key beeps but the engine will not turner over. I know its a ground of some type but what does it attach to???? please help. thanks paddy b
A big honkin' wire? Do you have a connection to the "A" stud on the alternator?
Your wire is probably the "Battery" connection to the alternator. If you hooked it to ground, you probably blew the 80amp ALT fuse in the under-hood fuse panel. (And if that fuse wasn't blown before, you would have one hell of a fireworks show!) That would de-energize AM1, and your truck is going nowhere.
On my 92 22RE, there's 3 connectors on that wiring harness. One plugs into the back of the alternator, one is the thick wire that bolts to the batt terminal on the back of the alternator, and a white wire with a black stripe that bolts to the cylinder head. There is no yellow wire with an eyelet.
I can't see the wire color on the bat wire to the alternator, it's shielded. If he did reverse them it will have blown the fuse and/or fusible link. A test light to the bat terminal should verify that.
WTB[International]: 93 P/u fuel door lock, roll bar, hitch, chrome rear bumper
Gamble_STi
Jun 27, 2015 07:54 PM
