1993 toyota 2wd 22re??? ignition?
Old Mar 20, 2015 | 03:38 PM
paddyb's Avatar
I have a yellow wire that comes off same harness as my alternater wire and plug on a 1995 Toyota truck 2wd 22re. does anyone know where this wire attaches. it has a eylet for a bolt to go through. I attached to block but the key beeps but the engine will not turner over. I know its a ground of some type but what does it attach to???? please help. thanks paddy b
Old Mar 21, 2015 | 07:24 AM
scope103's Avatar
A big honkin' wire? Do you have a connection to the "A" stud on the alternator?
Your wire is probably the "Battery" connection to the alternator. If you hooked it to ground, you probably blew the 80amp ALT fuse in the under-hood fuse panel. (And if that fuse wasn't blown before, you would have one hell of a fireworks show!) That would de-energize AM1, and your truck is going nowhere.
Old Mar 21, 2015 | 07:57 AM
paddyb's Avatar
1993 toyota 2wd 22re ignition help
I hooked 1 wire to alternator and plugged in the other wire. what and where does this other yellow wire go to. help. thanks
Old Mar 21, 2015 | 08:07 AM
paddyb's Avatar
the dash comes on, the key rings when you put in, the head lights come on!! the engine does not turn over. help.
Old Mar 21, 2015 | 08:11 AM
bswarm's Avatar
On my 92 22RE, there's 3 connectors on that wiring harness. One plugs into the back of the alternator, one is the thick wire that bolts to the batt terminal on the back of the alternator, and a white wire with a black stripe that bolts to the cylinder head. There is no yellow wire with an eyelet.
Old Mar 21, 2015 | 10:17 AM
scope103's Avatar
Originally Posted by bswarm
... There is no yellow wire with an eyelet.
Isn't the thick wire, bolted to the alternator, yellow?
Could paddyb have reversed the yellow and black-white?
Old Mar 21, 2015 | 01:28 PM
bswarm's Avatar
I can't see the wire color on the bat wire to the alternator, it's shielded. If he did reverse them it will have blown the fuse and/or fusible link. A test light to the bat terminal should verify that.
Weidle
Jan 21, 2019 05:39 AM
CJ94yota
Jul 3, 2015 10:14 PM
Gamble_STi
Jul 1, 2015 12:51 PM
Gamble_STi
Jun 27, 2015 07:54 PM
