Recently aquired 03 tacoma
Old Jan 22, 2015 | 06:27 PM
NRBTFOX's Avatar
Yesterday I got a smoking deal on an 03 Tacoma TRD. It just happens to have a hole in the block. I bought it after looking at just two pictures and knowing the block was toast. After getting the keys, I drove over to check it out. The truck has 165k on it and by the notes in the owners manual looks to be meticulously maintained up till about 110k. After looking at the golden brown oil on the dipstick that stopped just short of the full line, we started looking for the hole. Immediately I noticed there was no oil filter from underneath but could not find any traces of oil splatters, drips, or puddles. Then we saw the hole. I haven't got it to my house to look at it yet but was curious about thoughts on this hole.
Old Jan 22, 2015 | 06:33 PM
JasonYota's Avatar
Has the engine been running without an oil filter?? If I see the hole in the block it looks like it slung a rod.
Old Jan 22, 2015 | 06:45 PM
NRBTFOX's Avatar
I know nothing about the truck other than it got towed to where it's at and the records. My assumption it the filter got taken off while someone was looking at it. I'm more curious as to why there wouldn't be any oil sprayed throughout the engine bay.
Old Jan 22, 2015 | 07:51 PM
rworegon's Avatar
Someone may have forgot to put oil back in it during a oil change.
Old Jan 22, 2015 | 07:57 PM
NRBTFOX's Avatar
Oil was up to the full mark. Nice dark golden brown. Wasn't new wasnt old.
Old Jan 22, 2015 | 08:07 PM
JasonYota's Avatar
Oil could have been poured in after it slung a rod.
Old Jan 22, 2015 | 08:14 PM
NRBTFOX's Avatar
That would be my assumption too. But you can see that it's not brand new. I could very well be wrong, wouldn't be the first time. So next move, motor. What do you all think? Junk yard, short block,long block, "Jdm"? Truck has 165k on it.
Old Jan 22, 2015 | 08:31 PM
JasonYota's Avatar
Pull the current engine and see what happen. Then it's up to you, go back to the same engine or prefect chance for an engine swap.
Old Jan 25, 2015 | 01:16 PM
robb1887's Avatar
Easiest route would most likely be a drop in JDM motor. I've been looking for a "parts" motor to rebuild and the first one I got also had a windowed block. I cant seem to source a good short block alone to rebuild what I have, so the search continues.
You can find a good JDM motor around eBay from 900ish or so. They are pulled anywhere form 45-65K on them, but you're not really sure what you get.
Old Jan 25, 2015 | 07:34 PM
NRBTFOX's Avatar
The "not really sure what you get" part is what I don't like. I had a bad experience years ago. The motor I got spun a rod bearing about a month in.
Old Jan 26, 2015 | 05:12 PM
NRBTFOX's Avatar
Ok guys. Found a used motor with supposedly 20k on it. Pulled from a rolled truck 4 years ago. I have no way to verify mileage. Any tips you guys have to to somewhat verify? Things to look for?
Old Jan 26, 2015 | 06:24 PM
robb1887's Avatar
If able I'd pull the oil pan and one valve cover (Pass side since its easier) to get an idea of the internals.
Old Jan 26, 2015 | 06:53 PM
NRBTFOX's Avatar
I'll be honest. I have no idea what I'm looking for in that situation. I missed that class. I can tell if something's broken but that's about it. Obviously I can look at the oil if it's in there and look for signs of wear. But beyond that... (Insert blank stare)
Old Jan 27, 2015 | 12:44 PM
robb1887's Avatar
Just looking to make sure it looks good. no "fresh" shiney odd looking metal that would indicate new damage. All the stuff inside the VC and Oil pan should be oil saturated and used looking but "clean". No oil build up or gunk etc.
Old Feb 5, 2015 | 03:10 AM
waypoint's Avatar
Get the VIN of the truck it came out of and run a CarFax report on it.
westonian18
May 1, 2020 06:38 AM
rchavis
Jul 27, 2015 07:41 AM
KyleT
Jul 21, 2015 07:54 PM
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
