Leaky Windshield
Old Dec 17, 2014 | 10:32 AM
KBAM's Avatar
Leaky Windshield
Hey guys,
Bought my 91 SR5 3.0 about 3 weeks ago. Love it. Here in So Cal we just got a little rain and I soon figured out I had 2 leaks. Drivers side top corner of the windshield, and somewhere else leaking on my right foot under the dash. I haven't had a chance to investigate the foot area leak, but are there any common issues with leaks in that area I should look in to first? Not sure if its related to the windshield leak.
Thx in advance.
Old Dec 17, 2014 | 12:41 PM
Schnayke's Avatar
could always get some flowable windshield sealant and see if that fix's both. Only like a 4$ risk.
I am fairly sure there is a air intake for the climate control there, but it also could be traveling around under the dash.
Old Dec 17, 2014 | 09:48 PM
KBAM's Avatar
Great tip- thx, I'll give that a shot. After looking over the entire seal again, I can see where the seal has become pretty brittle in areas, but most notably the top where the visible leak is. Might be time to just get it replaced. We'll see! I plan on doing a lot of preventative maintenance on this truck to keep her road trip worthy.
Old Dec 18, 2014 | 06:22 PM
scottrweeks's Avatar
Try using roofing tar to seal it. I saw that on a car on Pimp My Ride. Seemed credible
Old Dec 19, 2014 | 01:22 PM
RAD4Runner's Avatar
Originally Posted by KBAM
...I can see where the seal has become pretty brittle in areas...
By seal do you mean the urethane adhesive used to stick glass to body OR the rubber gasket that some people use?
You normally would not see the adhesive until you remove the chrome trim or the rubber trim.
Chances are the rubber you see is not a gasket (used to really seal the glass to body), but rather just a trim. The urethane adhesive makes the seal.
Old Dec 19, 2014 | 02:50 PM
Terrys87's Avatar
Has the truck been in So Cal all its life? In my area, it is humid and rust gets behind the windshield. If it was in my area, I would suggest pulling the windshield, removing all of the old sealant and get the metal cleaned up. Windshield shops around here use a rust killer and then re-seal it. Leaky windshields is a fairly common issue on these trucks and is what I would suspect on yours.
Old Dec 20, 2014 | 10:41 AM
Teuf's Avatar
Rust did me in, it leaks.......I'll fit it for sure some day. Name:  IMG_2885.jpg
Old Dec 20, 2014 | 07:54 PM
jennygirl's Avatar
Dunno where in SoCal, but if you're in or around LA the place to go for windshield repair is Mission & Cesar Chavez area. I went to a place called Jalisco and they were really nice. I think there are about 70 auto glass repair shops in that area, so competition is fierce and prices are dirt cheap. I got a new windshield for my scion (that I just sold) including installation for $110. They did a great job, too.
Watch out though with the metal trim around the windshield. Some places are careless with those. If you take it to a shop, take before shots of the truck in case they do a crappy job and try to tell you that they did it right- happened to me!
Old Dec 20, 2014 | 08:01 PM
KBAM's Avatar
Thx for all the responses, guys. The truck is a so-cal truck, been here its whole life. To be safe (and for my piece of mind), I'm taking it to a buddy's shop next week to have a new seal put in. Hopefully they don't find any rust. Fingers crossed! Will post up the findings.
Old Dec 20, 2014 | 08:02 PM
jennygirl's Avatar
Good deal, and good luck
Old Dec 21, 2014 | 07:52 AM
Teuf's Avatar
Take pics, we want to see.
Old Dec 23, 2014 | 05:06 PM
KBAM's Avatar
Had my windshield replaced today. I'm happy to report that there was a minute amount of rust. (Pics coming, they are on my phone). The windshield had been replaced before by the previous owner from the looks of it, and the seal was an absolute hack job. (No pics of that)
Now on to bigger and better things, like the timing belt, adding a rear bumper (didn't come with one), suspension overhaul, new tires, brakes, etc.
Old Dec 23, 2014 | 05:17 PM
KBAM's Avatar
Other pic...
Old Dec 23, 2014 | 06:35 PM
Punchy's Avatar
Side note, Sometimes if its a manual the clutch peddle bracket will break the top mount to the body leaving a hole for water to come in.
shooter86314
Jan 7, 2016 07:05 AM
pickle6415
Dec 25, 2015 07:34 PM
bryan34w
12
Sep 30, 2015 02:50 PM
beltcutter
Sep 30, 2015 06:14 AM
