3.4 metal shavings in oil
I have a 96 Tacoma with a 3.4 at 199k miles. last time I changed the oil there were tiny gold flecks in the oil, no shavings on the magnetic drain plug.
I've put a few miles on it since and just pulled the dipstick and there were flecks on the dipstick as well but it's not making any noises or running worse.
How catastrophic is this? I don't know whether I should run it until it blows up or sell it and buy something else
I've used Blackstone Labs and they picked up when my HG was slightly leaking internally. At least you'll what the high values are and what might be generating the metal. Maybe take a peek under the valve covers too?
from my recent experience, i would take a look at all of your spark plugs before you drive it any more.
https://www.yotatech.com/forums/f120...engine-285120/
+1 on blackstone, they will tell you what particles are in the oil.
Just from the info provided it sounds like you're eating main/rod bearings and they are on the way out. If you catch it soon enough you should be able to just get away with replacing the ones that are bad without any other damage, run it too long and you have the chance of screwing up a lot more and having much bigger problems.
