Pre 84 Trucks 1st gen pickups
GM alternator instal and now no spark
Old Oct 1, 2014 | 05:06 PM
UPS's Avatar
UPS
So I have done umteen hours of reading builds, opinions and checking all kinds of how to's. I tried to get the wiring figured out before I started and thought I had it down. Got it all together and now no spark.
What I have is a 1980 20r, used a GM alternator with 3 wires. Bat. #1 & #2 on the plug.
I hooked #1 to the yellow/white for the Gen light, I hooked #2 to the large white wire that went to the original battery hook-up. #2 on the alternator is suppose to be the sensing wire for the charge actuator on the internal regulator. A least from what I have read.
So I get it put back together, all looks good and no spark from the plugs or coil. I have power to the coil (red wire at coil) and the engine fuse is good.
I haven't cut any other wires, or done anything other than this, so any ideas?
Last edited by UPS; Oct 1, 2014 at 05:08 PM. Reason: I tried to put this on my original thread but the "IT" godds don't seem to like me lately
Old Oct 3, 2014 | 08:07 AM
toastyjosh's Avatar
http://www.pirate4x4.com/forum/toyot...ml#post3453863
Old Oct 3, 2014 | 08:10 AM
toastyjosh's Avatar
http://www.toyotaminis.com/forum/int...or-swap-15714/
Old Oct 4, 2014 | 08:18 AM
UPS's Avatar
UPS
Thanks for the response toasty, I read most of the posts on pirate and wired it up just like the guy on toyotamini. I must have done something sideways.
On the stock wire loom there is a small red wire that has power with the key on. I was thinking to hook that to the #2 on the alternator.
If in the odd chance that I do have it wired correctly, what should I look for next?
Electrical is where I feel really dumb sometimes.
Old Oct 4, 2014 | 10:38 AM
toastyjosh's Avatar
Can you post a pic. that will help us trouble shoot
Old Oct 4, 2014 | 01:07 PM
UPS's Avatar
UPS
What I've done so far
Got one more to upload.
I won't insulated the wiring until I know it's all good.
!- the alternator in.
2- The #2 is on the stock large white thru the stock connector
3- You can see the red wire on the regulator plug that's powered with the key on
Attached Thumbnails GM alternator instal and now no spark-sn850393.jpg   GM alternator instal and now no spark-sn850394.jpg   GM alternator instal and now no spark-sn850395.jpg
Old Oct 4, 2014 | 01:31 PM
UPS's Avatar
UPS
This is the wiring to the coil, I haven't changed anything for stock. The red is hot (has power) with the key on.
Old Oct 5, 2014 | 07:59 AM
83Toyota88's Avatar
The large white wire in the truck harness should be connected to "Bat" on the alt. The red wire that tied to the old voltage regulator will connect to the "excite" terminal of the alt. Do you have any diagrams that show what #1 and 2 mean on the alt? One should be the excite and the other is the charge light I would assume.
Old Oct 5, 2014 | 04:22 PM
UPS's Avatar
UPS
Sorry, I'll try to copy the picture again
Old Oct 5, 2014 | 05:34 PM
UPS's Avatar
UPS
I connected the Bat. directly to the battery, the #2 to the Toy. large white and the #1 to the gen. light
Old Oct 5, 2014 | 07:23 PM
83Toyota88's Avatar
1 is the excite wire that causes the alternator to start doing it's thing. This must be tied to the ignition switch wire and nothin else. On my 83 it was a red wire. 2 needs to hook up somewhere that is just power. This is where the alternator will read the system voltage and determine how to regulate itself to maintain ~14VDC. Bat needs to be wired to the battery using the large Toyota white wire. This is the charge wire to the battery.
The way you have 2 might be ok. How did you connect the bat? Run a new wire? I considered that your 1 is still wrong though.
Old Oct 18, 2014 | 07:21 PM
UPS's Avatar
UPS
So I got back from a week on vacation and started messing with the Toy. I thought I was going to have to buy a new $350 distributor to take care of the no spark issue. I went to 5 different junk yards to try to find an igniter unit thinking that was the problem. Couldn't find any!
Turns out the contacts at the plug on my stock distributor were not making good contact. Pulled them out, cleaned em and she starts.
So far the alternator seems to charge fine with the set-up I used. I taped up the unused wiring and will use an inline fuse on the cable to the battery
80Truck
Oct 12, 2025 07:25 PM
raptor510
Feb 17, 2017 07:11 AM
redneck17
Oct 29, 2015 09:09 PM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
