sr5 cluster swap question
What year truck? I'll take a stab at it and say you probably want an SR5 instrument cluster out of a similar vehicle that was equipped with an automatic transmission. Donor cluster should come out of a vehicle with the same engine as well, so the tach works right without having to adjust it.
https://www.yotatech.com/forums/f116...estion-283228/
I pulled a cluster for my floor shift DLX ext. cab from an SR5 T100, and it has the shift points. I believe one should work for your truck. Funny thing, when I switched it out, I noticed that my truck was prewired for the reverse light only. Plugged it in, and the reverse light does light up! I did a little research in how to run the wiring for the other gears, but it was hard to find anything, so I gave up.
88yodabasket
Jul 13, 2015 01:32 PM
