sr5 cluster swap question
Old Sep 8, 2014 | 06:18 PM
greensteeldragon's Avatar
i have a auto with a column shifter, has neone replaced there cluster with a sr5 one? how will i know what gear im in?
Old Sep 9, 2014 | 02:37 AM
ditypup's Avatar
What year truck? I'll take a stab at it and say you probably want an SR5 instrument cluster out of a similar vehicle that was equipped with an automatic transmission. Donor cluster should come out of a vehicle with the same engine as well, so the tach works right without having to adjust it.
https://www.yotatech.com/forums/f116...estion-283228/
Old Sep 9, 2014 | 01:27 PM
91 v6
good link its how i found this place lol
BUT i have never seen a sr5 with the notation of gears on the cluster because they are all floor shifters
Old Sep 9, 2014 | 02:26 PM
dlx:
sr5:
the sr5 doesnt have a place for the PNDRL
or does it fit on the sr5 console somewhere, i have an extra sr5 digital cluster i can take aprt but not an extra dlx one yet
Old Sep 9, 2014 | 03:05 PM
JasonYota's Avatar
Is your truck 2wd or 4wd? I've never seen an older cluster like that with the gear indicators on it.
Old Sep 10, 2014 | 11:13 AM
apparently, i have a rare cluster, its 2wd v6 column shifter
Old Sep 10, 2014 | 11:34 AM
JasonYota's Avatar
Must be because it's 2wd. I'm sure you could convert your column shift to a floor shift. Or just install an aftermarket tach which might be easier.
Old Feb 21, 2015 | 11:44 AM
knew it had to exsist!
a 2wd sr5 cluster column shift
Old Feb 21, 2015 | 12:12 PM
Terrys87's Avatar
Looks like 89-95 cluster. I think that is the first one I have seen with the shift points in the cluster.
Old Feb 21, 2015 | 07:38 PM
Crapple21's Avatar
Looks like a t100 gauge cluster to me
Old Mar 2, 2015 | 09:35 AM
ycats's Avatar
I pulled a cluster for my floor shift DLX ext. cab from an SR5 T100, and it has the shift points. I believe one should work for your truck. Funny thing, when I switched it out, I noticed that my truck was prewired for the reverse light only. Plugged it in, and the reverse light does light up! I did a little research in how to run the wiring for the other gears, but it was hard to find anything, so I gave up.
gary4runner
Sep 24, 2015 12:53 AM
88yodabasket
Jul 13, 2015 01:32 PM
Rkellerman
Jul 12, 2015 08:42 AM
Coreyr384
Jul 10, 2015 11:13 AM
Cplmike
Jul 8, 2015 08:47 PM
