94 22re 2wd 5spd cant set timing help!!
Old Jul 31, 2014 | 07:10 PM
sick7one's Avatar
just put a new crower stage 2 efi cam and noticed cam gear was one tooth off(corrected that), set everything up as far as mechanically time, but with timing light it reads way too far advanced and idle also surges after coming to a stop..(btw im using the jumper and useing info off all data at work) just cant seem to figure out why it wont time right
Old Jul 31, 2014 | 07:17 PM
millball's Avatar
Make sure TPS is good and correctly adjusted.
Timing won't return to base advance if the TPS is not telling the ECU that the throttle is closed. Happened to me.
Old Jul 31, 2014 | 08:41 PM
Gamma_Hugo's Avatar
i had an idle surge as well when i came to a stop. The issue with my truck was a clog in the Idle Air Control Valve. There could be a clog or an air bubble somewhere in your cooling system.
Did you connect the ports in the diagnosis port to set the timing and adjust the distributor?
maybe a vacuum leak?
Old Jul 31, 2014 | 10:24 PM
sick7one's Avatar
Yes I'm using a jumper to set timing, I'll check the tps and iac valve thanks guys
Old Aug 1, 2014 | 11:15 AM
Gamma_Hugo's Avatar
Good luck!
Hopefully it's nothing too difficult to fix or expensive.
Ichneumon
Sep 27, 2015 04:21 PM
noahstancik
Jul 10, 2015 11:18 AM
83flatt
Jul 2, 2015 10:30 AM
DanStew
Jun 29, 2015 10:46 AM
