Pic request of underwood fuse panel
Edit....yes underhood fuse panel, or whatever the technical term is. Stupid ipad correct.
If someone can post pics of their fuse panel cover that still has the sticker on it, I would appreciate it very much.
I have two here and both are just black with no info as to what it what. Doing some wiring reconfiguration and would rather not guess which fuse is for what circuit.
Working on both 22re and 3.0 86-88 runners. It's the small, L shaped panels. If you can post yours, please include the year and motor yours has.
The "Underwood" fuse panel is for the built-in typewriter. I think it was only an option in '88.
Relay Block 2 http://personal.utulsa.edu/~nathan-b.../2powersou.pdf contains fuses and is under the hood. Presumably, the configuration is different for dntsdad than that shown in the '93 manual.
Looking at it from the front of the truck.
in the back head light relay
the 4 fuses right head light charge fuse
left head light Haz/Horn
AM2 AM1 80 amp
AM1 40amp
this is the 22REC 86
AM2 AM1 80 amp
AM1 40amp
Fuse labels on mine...
1987 standard cab 4x4 with the 22rte/5 speed. I've seen the same label on 22re's at the junkyards. Can't speak for the 3.0 though.
I also have the 1987 FSM and Electrical Wiring Diagrams. One of these days I'll get around to scanning and making a .pdf out of them...
Underhood fuse panel cover:
Driver's kick panel fuse cover:
Diagnostic box label (inside the cap):
theking11863
Mar 19, 2016 09:36 PM
FS[PacNorWest]: Kick panel speaker pods
AkitaDog
Jul 27, 2015 02:38 PM
rushw
Jul 18, 2015 01:46 PM
A little Help here Please just what is a Underwood Fuse panel??
I don`t get out much so I thought I missed a aftermarket company.
