4 hole 3.0 injector install, kinda broke something....
Old Jul 6, 2014 | 07:06 PM
saltie's Avatar
Hey guys, been here many times kinda lurking and stalking.... Kinda being a creeper. Well anyways I got the upper intake off and i was pulling out the fuel rails and when I pulled off the back crossover line the vacuum line attached to it snapped off on what looks like a sensor. This kinda sensor also had another vacuum line going to it and I an wondering if it's worth looking for this part or should I bypass it or cap it maybe? It just seems like I need some advice since the reason I'm changing to the flame thrower 4 holes in the first place is because I had a fuel leak and I'm looking for the source (which I have no idea where it is still....). Hey and while I'm on here where can I get these size crush washers? I'll head to the auto parts store tomorrow I'm just hoping they have them.... And if u have any advice as to where my fuel leak may be let me know! Again, thank you and I hope to start posting more now that I've stopped being the guy at the window and finally forced my way in and am now the guy in the corner...
Love,
Andrew
Attached Thumbnails 4 hole 3.0 injector install, kinda broke something....-image.jpg
Old Jul 6, 2014 | 07:07 PM
saltie's Avatar
More pictures!!
Old Jul 6, 2014 | 07:09 PM
saltie's Avatar
And last picture with new sexy injectors!!
Old Jul 6, 2014 | 07:13 PM
saltie's Avatar
Oh yeah and these are the size crush washers I need... Please send me good vibes so I can find them tomorrow.... I really hope this is why I smelt gas at idle and saw it dripping fuel on the exhaust crossover, I'll once over it before I put the upper back on! Sorry for rambling my friends, happy trails!
Chow,
Andrew
Old Jul 6, 2014 | 07:20 PM
rworegon's Avatar
Your local Toyota dealer will have those washers. Some auto parts places may have them.
Old Jul 6, 2014 | 07:24 PM
saltie's Avatar
Thanks man! I'll see tomorrow how has them... I am worried about that sensor thing though, if it come down to it I'm gonna bypass it if you all can't help me! Not doubting you guys or anything!!
Your's truly,
Andrew
Old Jul 6, 2014 | 07:31 PM
rworegon's Avatar
I'm not a 3.0 guy, but I've seen plenty of threads around here where that sensor broke off the nipples just like yours.
The 3.0 guys will find this thread an chime in. Found this: https://www.yotatech.com/forums/f116...sor-do-237236/
Old Jul 6, 2014 | 07:45 PM
scope103's Avatar
Originally Posted by saltieballz
... what looks like a sensor. This kinda sensor also had another vacuum line going to it and I an wondering if it's worth looking for this part or should I bypass it or cap it maybe? ...
Thermal Vacuum Valve (TVV) or Bimetal Vacuum Switching Valve
http://www.toyotapartsoverstock.com/...092505047.html
You will only find it at a dealer. Some on this site (claimed to) have successfully repaired them, but I doubt you have enough good plastic left to do that. (I didn't) It drains fuel vapors from the canister into the throttle body; when the engine is cold is shuts off to improve idling. You can probably bypass it, but you may end up with a rough cold idle at times.
... I really hope this is why I smelt gas at idle and saw it dripping fuel on the exhaust crossover, ...
The component in that picture is the Fuel Pressure Damper. https://www.yotatech.com/forums/f116...octite-266710/ It is a fairly common source of leaks. Alas, you can't tell if the part is bad without buttoning it back up again. But when you get the fuel rail back together, test just that with the FP / B+ in the diagnostic connector, BEFORE you put the plenum back on.
I've never found the crush washers anywhere but the dealer, but even there they're cheaper than dirt. Get yourself a few extras. They are one-time use; don't believe anyone who says you can re-use one. (There is a reason they are called 'crush' washers.)
Old Jul 8, 2014 | 07:23 PM
gareth's Avatar
I have broken two of them.
Search Ebay, they are out there used.
I have mine currently bypassed as I broke the damn thing just as I was finishing up last time when I put my engine in.
I will fix it this fall when I replace the injectors.
*I* know it's broken....and that is enough.
For what it's worth, I haven't noticed any issues with it bypassed.
Old Jul 8, 2014 | 07:37 PM
gareth's Avatar
BTW, they are quite proud of them new....hence my suggestion to find a used one.
Old Jul 8, 2014 | 07:58 PM
scope103's Avatar
Originally Posted by gareth
... Search Ebay, they are out there used.
How much do you save by replacing a $49.97 part with a used one from eBay? $20? $25?
Each to his own.
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
shar
Jul 9, 2015 12:38 PM
skoti89
Jul 6, 2015 07:45 PM
karbin
Jul 5, 2015 11:37 PM
