stock carb jet sizes
Just picked up an 80 4x4 and am working out some kinks etc. I've decided to run the truck on the stock carb but think that I may need to lean up the main jet a bit. Reason being is that I'm about 4000 feet above sea level. Does anybody know the size of the stock main..... And also where I could find alternate sizes?
I have sometimes lo temp silver brazed jets closed and redrilled them.
You need a good unmutilated set of number drills to use to gauge the existing hole; so you can decide how you want to redrill.
A very small change does a lot.
I'm using Weber jets on my 22R carb prim. on a 20R/22R eng. I think I ended up with a #18 on the prim,. tuned with my LC1.
Loosed spring on the top the sec. plate to about 5 o'clock. Truck has never ran better. I'm at 2200 ft.
Isn't part of the point of the stock carb that it compensates for altitude? I've never known of anyone re-jetting a stock carb. They do it all the time with Webers, though.
I have some vague memory of maybe some stock carbs not having the high altitude compensation equipment in them...I don't know. I've always lived in the intermountain west (since I started driving) and every truck I've owned with a stock carb does fine at whatever altitude.
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
coffey50
Jul 28, 2015 10:55 AM
