92 22re w/auto lacks power going up hill
just got this 92 pickup for my wife it has the 22re and automatic tranny the odometer say's 206,000 I will also add its running 31 km2's now the truck. the truck sat all winter the guy I got it from started it like once a week to keep it running I bought it and drove it 50 miles to get it home. the next day we toke it up are road further and there is a steep hill as we started up the truck just didn't seem to have any power I really had to put the pedal down to get it to take off . i just changed the oil in it which was the only thing that the guy hadn't changed {plugs,wire,cap,coil fuel filter etc. are all new} we took it back up the same hill and it did the samething again { i know oil wouldn't change anything just wanted to give it a run} does anybody know what is causing this ? the tranny fluid is full and looks and smells good. i have also noticed that at idle in park it feels/sounds like it is idling a little fast and once i put it in gear its seems like the truck vibrates a lot . i plan on putting this on the road soon and want it safe for her to drive plus we really want to get on some of the trails and back roads . any help on this would be great, i should also say that i ran just about all the gas that was in it out and just put 4gls. of fresh gas in it. sorry to make this so long but wanted to put all the info i could in it , again thank for any help.
Your in Vermont what might be a hill to you very well might be thought of as a mountain to some of these flat landers.
The 22REC with the auto is not a power house .Your only talking a little over a 100 horse power.
Then the bigger then stock tires don`t help
How did it drive coming home?? It might get a little better once some fresh gas is run through.
New Air filter as well or was that over looked Now you say this engine had a major tune up ??
You bought this off a trusted friend or We have all seen and heard I just tuned this up not more then 20,000 miles ago not more then 3 years ago so all is good.
Good luck !!
Good luck !!
I would check compression to get an idea how the engine is doing, 200k is getting up there. But agree with above, the 22re with an auto is no powerhouse. As for the vibration, have you checked the motor and tranny mounts?
In my 87 with a 22re, 5speed and 31s (with 4.10s) , a lot of hills were 3rd gear pinned hills. Adding 4.56s helped alot.
Good luck !!
Good luck !!
I think it is what it is . Then the engine is getting tired but a brand new rebuild really would not get you much more.
I hope the wife is just planning to use it to do local trips.I know my 4Runner with my normal load of stuff would stop at the Vermont Line and refuse to move just like a Mule.
Trying to drive this on the interstate will get her blown off the road by the Canadian Log Trucks I was just up to Burlington on the 14
People on the Interstates seem to either have one or the other pedal to the floor
It sounds like gearing/tire size is the biggest problem. Toyotas that came from the factory with auto trannies and 31s had 4.88 gears. Yours might have 4.30 gears (just a guess). If you look at the sticker by the drivers door, it will have a gear code, this will tell you what it originally had. For example G144=4.88. That being said, a strong or tired motor will make a big difference also. For now make sure to use 4lo for any off road trips and for everyday driving fill the tank with super (93 not 91). It really does help these little engines and it's only a few dollars more at fill up.
Either your state has mandated some strange additives or you just get really bad gas up there.Even my 3.4 ran like I had 1200 pounds in it.When it was empty that could also be part of the problem
Once I got gas down in Rotten Dam burned about 1/4 tank it seemed to be it`s old self.
Jeffreynmandy
Jul 18, 2015 08:26 AM
the1998sr5
Jul 16, 2015 06:20 AM
