I'm new to this - 3vz 3.0 trouble removing crankshaft gear
Having a problem getting a crankshaft gear off my 3vz 3.0. screw drivers won't make it budge and I don't have pullers that will fit behind it and the oil pump housing area. WTF to do?
yup
There is a treaded hole for the crankshaft nut, but the steering wheel pull I bought was heavy aluminum, is now bent to heck, and destroyed my vibration damper.
Last edited by rworegon; Jun 22, 2014 at 02:15 PM. Reason: Removed word censor picked up.
Ok, I'm a bit confused. What part is giving you difficulty? The vibration damper i.e. crank pulley the auxiliary belts run on or is it the crankshaft gear that the timing belt runs on?
Pic if you can would be helpful.
On the 5vz-fe 3.4, the crankshaft gear has two tapped holes 180 degrees apart which makes using the steering gear puller easy. Yours does not have those holes correct?
Getting some PB Blaster or other good penetrant on there may help. Rust tends to form between the crank and gear.
Hopefully, the 3.0 guys chime in some with some ideas for you.
Ah, the early style before the holes. Some have had luck with penetrant and the screw drivers and others have had to drill and tap holes (post 7) to get it off.
Rh & Lh Camshaft gears off...and oil seals.
Looking at the LH camshaft seal port, it looks like oil has been heated. Not so much on the Rh side. This is after the sprockets were removed after receiving the tool purchased at Amazon.com
Yes, LH and RH from your viewing perspective at the front of the engine. However, Toyota calls LH the driver side and RH the passenger side as if your are sitting in the cab looking into the engine bay.
Why do I mention this? Some timing belts have R and L painted on them for ease of lining up on the proper cam mark.
A little leak/seep on the passenger side cam side for sure.
