Sponsored by: CARiD
I'm new to this - 3vz 3.0 trouble removing crankshaft gear
Old Jun 22, 2014 | 02:01 PM
Joe Hilux's Avatar
Having a problem getting a crankshaft gear off my 3vz 3.0. screw drivers won't make it budge and I don't have pullers that will fit behind it and the oil pump housing area. WTF to do?
Old Jun 22, 2014 | 02:06 PM
rworegon's Avatar
Does it have the threaded holes in it so a steering wheel puller will work?
Old Jun 22, 2014 | 02:10 PM
Joe Hilux's Avatar
yup
There is a treaded hole for the crankshaft nut, but the steering wheel pull I bought was heavy aluminum, is now bent to heck, and destroyed my vibration damper.
Last edited by rworegon; Jun 22, 2014 at 02:15 PM. Reason: Removed word censor picked up.
Old Jun 22, 2014 | 02:14 PM
Joe Hilux's Avatar
Will brake fluid work better as a corrosive remover/lubricant that WD40?
Old Jun 22, 2014 | 02:16 PM
Joe Hilux's Avatar
I mean Brake cleaner..
Brake Cleaner....I meant?
Old Jun 22, 2014 | 02:18 PM
rworegon's Avatar
Use something like PB Blaster. The auto part store, Home Depot, etc. has it.
Old Jun 22, 2014 | 02:22 PM
Joe Hilux's Avatar
Ok.
Thankx much.
Old Jun 22, 2014 | 02:23 PM
rworegon's Avatar
Ok, I'm a bit confused. What part is giving you difficulty? The vibration damper i.e. crank pulley the auxiliary belts run on or is it the crankshaft gear that the timing belt runs on?
Pic if you can would be helpful.
Old Jun 22, 2014 | 02:40 PM
Joe Hilux's Avatar
The Crankshaft Sprocket (Gear) won't budge off the crankshaft.
Joe Hilux's Avatar
I'll try to take a picture. Will take a little while.
Old Jun 22, 2014 | 02:49 PM
rworegon's Avatar
On the 5vz-fe 3.4, the crankshaft gear has two tapped holes 180 degrees apart which makes using the steering gear puller easy. Yours does not have those holes correct?
Getting some PB Blaster or other good penetrant on there may help. Rust tends to form between the crank and gear.
Hopefully, the 3.0 guys chime in some with some ideas for you.
Old Jun 22, 2014 | 02:56 PM
Joe Hilux's Avatar
Pics of truck and problem.
Hope there's a simple and cheap solution to remove.
Attached Thumbnails I'm new to this - 3vz 3.0 trouble removing crankshaft gear-img_20140622_154717.jpg   I'm new to this - 3vz 3.0 trouble removing crankshaft gear-img_20140622_154649.jpg   I'm new to this - 3vz 3.0 trouble removing crankshaft gear-img_20140622_154532.jpg
Old Jun 22, 2014 | 03:05 PM
rworegon's Avatar
Ah, the early style before the holes. Some have had luck with penetrant and the screw drivers and others have had to drill and tap holes (post 7) to get it off.
Old Jun 22, 2014 | 03:11 PM
Joe Hilux's Avatar
Vibration damper rage effects
Just Look at the Idiocracy of the 3.0
Attached Thumbnails I'm new to this - 3vz 3.0 trouble removing crankshaft gear-img_20140622_154626.jpg   I'm new to this - 3vz 3.0 trouble removing crankshaft gear-img_20140622_154703.jpg
Old Jun 23, 2014 | 05:12 AM
Joe Hilux's Avatar
If I ever get the oils seals finished, I'm considering leaving the Timing Belt Covers off. Will this have any immediate adverse affect on the engine or components ?
Old Jun 23, 2014 | 05:39 AM
rworegon's Avatar
Seems like a good way for a lot of grime to get into the TB teeth and even introduce substances to the belt that may weaken it.
Old Jun 24, 2014 | 02:36 PM
Joe Hilux's Avatar
Rh & Lh Camshaft gears off...and oil seals.
Looking at the LH camshaft seal port, it looks like oil has been heated. Not so much on the Rh side. This is after the sprockets were removed after receiving the tool purchased at Amazon.com
Attached Thumbnails I'm new to this - 3vz 3.0 trouble removing crankshaft gear-img_20140624_151216.jpg   I'm new to this - 3vz 3.0 trouble removing crankshaft gear-img_20140624_151223.jpg   I'm new to this - 3vz 3.0 trouble removing crankshaft gear-img_20140624_151231.jpg
Old Jun 24, 2014 | 03:02 PM
rworegon's Avatar
Yes, LH and RH from your viewing perspective at the front of the engine. However, Toyota calls LH the driver side and RH the passenger side as if your are sitting in the cab looking into the engine bay.
Why do I mention this? Some timing belts have R and L painted on them for ease of lining up on the proper cam mark.
A little leak/seep on the passenger side cam side for sure.
Old Jun 24, 2014 | 03:39 PM
Joe Hilux's Avatar
I still haven't found the secret to removing the crank sprocket off yet.. I've tried quite a few methods and no success yet. It's on there.
Old Jun 24, 2014 | 03:58 PM
rworegon's Avatar
You may have to drill and tap that bugger to pull it off.
