Speedo is off a whopping 32%!!!!
Hey everyone. Haven't had much luck getting replies on here but I thought I'd try again. Really need some expertise on my speedometer gearing. The transmission was toast and replaced but I didn't realize the gear for the speedo should be checked to see if they were the same and ended up scraping the old trans. So I need help on figuring this out. I don't know the rear ratio but I do believe it's stock. This is an 87 2wd 22r if that helps. The tires are 235/75-15. 20mph is 35. 35mph is 55. And 48mph is 70. I'll try to look and see what speedo gears I actually have today. Thanks for any help.
http://www.toyotapartsoverstock.com/...340329145.html
Confirm info, but this could be yours for <$30
Is the stock rear end a 4.10? If so my current gear is a 35 and best I can tell my driven gear is a 6 tooth. That would mean according to the speedo gear calculator I used, I need a 17.4 rounded up? To make my speedometer spin faster I need a smaller tooth gear correct?
I think you have a bigger issue than the wrong size gearing. If your numbers are correct, the percent error is not constant with speed. 35/20=1.75. 55/35=1.57. 70/48=1.46. Beyond that, errors that big can't be explained by the wrong gear ratio and tire sizes. Even going from 4.88 to a 4.10 gearing, which is the largest stock change you can make, is only a ratio of 1.2 to 1, far less than the errors you are seeing.
I would say, since it's a cable drive, that you have a defective speedometer.
These speedometers aren't on a curve? I didn't think they were linear. I had read a thread where they were saying if you're consistently off by like say 5mph. It's because your needle is off. But if you're speed difference changes that it's the gearing. I'm not looking to be perfect but I could deal with 1-5 mph off. Does the speedometer drive the odometer? That's what I'm trying to fix other than making sure my speed is accurate. Makes it hard to do mileage when it's off like that.
If the gearing is off, the speed difference should change, but the ratio of actual speed to indicated speed should stay the same. For example, if it reads 30 at 20mph, it should read 60 at 40mph. If you look at my original reply again you'll see that's not the case for the numbers you gave. So, just changing your gearing (if you even could by that large of an amount) will only fix your errors at one speed. It'll still be off at other speeds.
You should check your odometer against interstate mileposts and see how far it's off. That will give you another data point to sort this out.
So over 10 mile markers. I did 5.7 miles on my odometer. Or an error of 43% and I think some of the numbers I quoted were a bit off. Stopped by the toyota stealership and the parts guy had a hard time helping me because he wanted to use my vin to look it up. But my truck came as a four speed but is currently a five speed. The gear I have is stamped 10-35 but he said he had an 11-27 will that work or is the pitch going to be off? I don't know why toyota would make a transmission gear in 10 and 11. He wanted $40 for it but I found the same part online for 27. I just want to make sure it'll work before I try it. I don't mind trial and error to an extent but I don't want to chew up a $27 piece of plastic. Lol
according to this thread: http://forum.ih8mud.com/threads/spee...change.480939/
the first number (11 or 10) refers to the number of teeth (pitch) of the DRIVE gear. So if you "need" a 10-xx then an 11-xx requires you to replace the drive gear inside the transfer case. (Which, while a bigger job, can certainly be done. Certainly if you can change transmissions.)
I can change it but I didn't. And there is no t-case it's 2wd. I'm pretty sure there's a gear out there that will work. I'm just looking for a place where I can see what gears are available. I've searched and haven't had much luck
Try this:
http://www.toyotapartsoverstock.com/...348122020.html
This guy: http://www.celicasupra.com/forums/sh...350#post849350
said it was "easy" to change on a Celica, and his photo of the clip looks very similar to part 33481E for the toyota.
charlie_fong
Sep 27, 2015 10:06 PM
travisamorgan
Sep 2, 2015 01:00 PM
94ofCanada
Aug 14, 2015 06:37 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
