Thrust Angle Off by 0.3 degrees
Old May 20, 2014 | 12:31 PM
phillipeino's Avatar
I bent my rear passenger lower control arm a couple weeks ago, replaced it with a new stock arm, and now my rear thrust angle is at -0.30 degrees. A week before I bent the CA, the rear thrust angle was at -0.06 degrees. Nothing else looks bent in the rear. It does kind of drift to the right, but not sure yet if that's because of the crowned roads.
1) Is -0.30 degrees enough to be worried about?
2) What would I need to be able to adjust the rear thrust angle? An adjustable pan hard bar or adjustable upper/lower control arms?
Here are the alignment settings(new CA / old CA)
CAMBER LEFT: -0.1 / -0.3
CAMBER RIGHT: -0.4 / -0.2
TOE LEFT: -0.32 / -0.05
TOE RIGHT: 0.27 / 0.07
CROSS CAMBER: 0.2 / -0.1
TOTAL TOE: 0.05 / 0.02
THRUST ANGLE: -0.30 / -0.06
Thanks
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
voiddweller
Sep 28, 2015 11:21 PM
