87 toyota pickup running rough
I recently bought an 87 5 speed 22r 4x4 solid front axle. The truck sat for a about a year before i bought it and its running rough. I changed the oil and filter. Truck is idling high and smokes when given throttle. it doesnt have nearly the amount of power that it should. I put some seafoam in the gas and it helped the truck run smoother but not much better. Where should I start?
Well what type of smoke are you seeing out the tail pipe? If its running rough there are a number of things to look at. Does it go away when you go to higher rpms or does it get worse? Does it stumble at all before you get it rolling? Did the carb have fuel in it when it sat? Check your plugs and wires. Check everything you can easily get to. Air filter ect.
Very generally, engine smoke is white (due to coolant in the exhaust), blue (oil), or black (unburned hydrocarbons, usually meaning an over-rich condition).
Can you classify the smoke by this sort of color scheme?
Well check your plugs. If you see white or perfectly clean plugs then most likely you have a bad head gasket. If the plugs are clean but there is still smoke then you may have a crack in your head where the water jacket runs past the exhaust valves.
So once it warms up the problem is less noticeable? If it gets higher when you rev but isnt in your oil its a good possibility that your combustion is converting the coolant into steam before you get blow by into your oil sump. That's why I say check your plugs. A head gasket leak does not always mean oil and water will mix.
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
