front brake replacement 79 toyota
Hilux is right take the hub and rotor and get a BFH and pound out the wheel studs and then tnere is two bolt to remove, if you use brass to pound them out you should be able to reuse them
They've got it right, the hub comes off to replace that rotor. Might as well consider getting new bearings and rebuilding those knuckles while you've got it that far apart. And get some new wheel studs, because you likely won't get the old ones out without beating the living ˟˟˟˟˟ out of them and damaging the threads. And have a press ready to press in the new wheel studs because a hammer isn't going to seat them down all the way. Other than all that, it's a piece of cake!
Oh, and you'll want some good snap ring pliars and you'll need a 54mm socket to get those spindle nuts off. I actually use a 2 1/8" craftsman socket from sears for mine - fits perfectly.
Aleeex_u
Jun 5, 2016 06:52 PM
voiddweller
19
May 2, 2016 09:10 PM
YotaGreenhorn
Jun 27, 2015 07:00 AM
Mr.Black
Jun 21, 2015 10:17 AM
This didn't work for mine cuz mine were seizewelded solid to eachother Lmfao
