1986 22r pickup with bad head gasket and maybe rod broke??????
i have a 1986 toyota pickup 22r 4x4 and it has bad white smoke coming out exhaust+antifreeze running out the exhaust manifold+ 2 cylinders full of antifreeze bc the spark plugs are covered in antifreeze no milky oil thou and it knocks like no tomorrow... what do i do and is it the head gasket? rod? or what?
well started the tear down dont have head off but no oil and water mixture just antifreeze everywhere its in cylinders 3&4 and was pouring out exhaust most likly i need a new head right??
well this Is what I got a burn??? on block about 1/8 in deep and head is warped and burnt too(same depth) is pretty bad I need a new block or maybe something else I have no clue im at a rock and a hard place
Wow!!
Don't think you can deck the block enough to save it.
Head is junk for sure.
Both parts might be repaired with specialist welding and machine work,
but other parts could be got cheaper for sure.
finished
well its been a long time but i finally got a head rebuilt and all brand new by a friend at a head shop also i had to get a newer block bc mine had a crack that we never seen untill i took it out and cleaned it but now here she is
Its the ford blue(I know I hate the name) paint from advance autopart... its in the truck just put it in 2weeks ago!!! I got 2000 miles on it and Black betty is alive!!!!!!!! Me and my father did the full rebuild!!!
zd92655
Mar 6, 2022 12:58 PM
voiddweller
19
May 2, 2016 09:10 PM
