1985 22re recent rebuild low power a/t
Friend brought truck to me, just had it rebuilt. Flashed codes and had 2, 7, and 8. Did test on MAF and tested bad, so I replaced . Also found 3 or 4 cvacuum lines leaking and replaced plugs with ngk instead of autolite. Also replace cts due to corrosion. Seems to run ok but best when fully advanced. Distributor is on time and compression across the board is any wje from 120 to 145. Has low power especially when put in gear and no take off power.
I would say that is a start to the issues. You need to get a known good AFM and see if it makes a difference. I had s similar issue last year and it was the AFM.
Also, Hows the timing? What is it set at?
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Vargntucson
Jul 4, 2015 12:15 PM
