1992 toyota pickup 22re wont run
I have replaced the fuel pump, fuel filter, mass air flow meter, (TPS) throttle position sensor and it still wont run it starts up for about 5-15 seconds and stalls. I drove it 5 miles down the street it sat for a hour then i went to leave and then it started doing this what do you guys think my problem is ??? Please help.
What you did is jumped the fuel pump part supply top the battery basically. The MAF sensor or AFM on these is the sensor that is in the metal housing on your air filter box. The fuel pump is engaged when you turn the key to start. But after the vehicle is started it depends on the AFM for its voltage signal. You more than likely just need a new AFM.
Could be a fuse or relay. I would check all fuses with a test light and try swapping around some of Relays behind the passenger kick panel. One of those relays powers a bunch of stuff with the key in the run position.
The AFM has a metal flapper door that opens when air blows through it. Try propping that door wide open then see if it will run.
6th Gear
19
Dec 10, 2019 07:31 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
