Bilstein BTS-7514 in 3rd Gen 4 runner
Old Mar 11, 2014 | 07:42 PM
RattleAKAK's Avatar
So I am about to drop cash on some Bilstein 5100 (24-188265) shocks to go with my TRD YYYB, for my 99 4 runner. However I just found a set of Bilstein BTS-7514 for a smokin deal. Has anyone ran these? The top hat/collar etc is different and it has a threaded adjustment versus perches. Anyone know if these would work. advice? Thanks
Old Mar 11, 2014 | 09:47 PM
RattleAKAK's Avatar
So I went ahead and grabbed them,
After doing some research I just need a top mount like this
If I can't buy one I'll make a set, I will be updating this thread as I progress with install etc. with ride height, quality and such. Any input is much appreciated
Old Mar 12, 2014 | 04:35 PM
RattleAKAK's Avatar
Ordered the top mount from AllPro. Great customer service.
Old Mar 15, 2014 | 09:50 PM
MauiJim's Avatar
They look beefy- update once you get them on!
Old Apr 1, 2014 | 09:17 AM
Taco Burrito's Avatar
Did you install them? What's the status on these? I'm interested.
Old Apr 1, 2014 | 01:05 PM
RattleAKAK's Avatar
I have almost assembled all the parts to complete the project. The upper mounts arrived from AllPro and I am heading to one of the largest swap meets in the US this weekend to hopefully find a Sonoran Steel adjustable panhard bar. As soon as the parts pile is complete, it will be up to mother nature on when I get this done. I will post the build as I do it.
Old Jun 19, 2014 | 06:21 PM
RattleAKAK's Avatar
Finally!!!! Installation complete!!
Last weekend I was able to get my 99' T4R all put together. I used a set of Bilstein BTS-7514s for a 2000 Tundra. It worked slick. I ran in to no problems at all other than the Marlin Crawler Extended Brake line kit didn't have the right front lines in it but I am working with MC on getting the right ones sent out. Parts I used are as follows:
Bilstein BTS-7514 Coilovers for 2000 Tundra
8 wrap LC coils
LC rear shocks
1994 Toyota Truck sway bar end links for the rear due to they are a couple inches longer and I want to run a rear sway bar
Marlin Crawler Stainless braided extended brake lines 3"
RevTek Diff drop
Front sway bar drop kit
AllPro Top Mounts
This is the before
Coilover Install - I set the preload to 4.5" from center of lower shock eye to coil adjustment nut surface
Top Mount - All Pro top mounts
After
All in all I gainer 3.5" in the front and almost 5" in the rear. Rides like a dream!!!!!!!!
Old Jul 28, 2014 | 12:14 AM
RattleAKAK's Avatar
After about 500 miles on the truck after the lift both inner CV boots started leaking. Passenger side finally let loose completely and driver side wasn't far behind. $104 for a reboot kit from the dealership. It's actually not a hard job, just messy. My least favorite was part was cleaning the grease from my control arms etc.
Jun 1, 2021 01:51 PM
Steezy96yota
Jul 6, 2015 10:00 AM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
