1987 yota 22r
Old Feb 19, 2014 | 09:58 PM
87yota599's Avatar
Hey there. I have a 1987 toyota pickup 4x4 with a 22r. Would I be able to just get the re intake and some of the wiring and be able to have a running re on my stock 22r? Thanks
Old Feb 20, 2014 | 01:43 AM
wyoming9's Avatar
Red face
No it is not quite that easy!!
You would need the engine harness with sensors and the ECU
You would also need to upgrade the fuel system to the higher pressure needed for the injectors
If this is what you meant by getting the intake and fuel rail and some of the wiring .
Then it would be Yes
Old Feb 20, 2014 | 06:03 AM
Terrys87's Avatar
If you mean a full on conversion from a 22r to 22re that is a big No. You have to do a major tear down from one end of the truck to the other. I am currently doing one and will be doing some more later today. Here is what I have gotten done so far. https://www.yotatech.com/forums/f199...l#post52146627 and on to the following pages. I figure I am 40% done.
I will eventually make a thread doing it step by step, but even still there is alot of information that would take a book to write as of all of the differences in the wiring, injectors, and so forth. You have to swap tanks, fuel lines, gut the interior, it is a big job.
Old Feb 20, 2014 | 10:28 AM
87yota599's Avatar
Originally Posted by wyoming9
No it is not quite that easy!! You would need the engine harness with sensors and the ECU You would also need to upgrade the fuel system to the higher pressure needed for the injectors If this is what you meant by getting the intake and fuel rail and some of the wiring . Then it would be Yes
Ok. Well what can I use off of my 22r.
Old Feb 20, 2014 | 10:33 AM
wyoming9's Avatar
Red face
The block
head with the fuel pump block off plate
Alternator
Starter
Power Steering Pump.
Old Feb 20, 2014 | 10:38 AM
87yota599's Avatar
The block head with the fuel pump block off plate Alternator Starter Power Steering Pump.
Ok. Do I have to rebuild or can I leave the motor the way it is? I don't have power steering yet. Lol. Did come on my truck.
Old Feb 20, 2014 | 10:40 AM
wyoming9's Avatar
Red face
Only you know what shape the engine is in.
How many miles ??
Last timing chain??
Old Feb 20, 2014 | 10:47 AM
87yota599's Avatar
Only you know what shape the engine is in. How many miles ?? Last timing chain??
I could tell you. I just got it about a month ago and have been having problems with the carb ever since. And I think it has had a timing chain done. And it's got like 206x
Old Feb 20, 2014 | 06:35 PM
AZBlue86P/U's Avatar
What kind of problems are you having with your carb? Is it stock? You might also want to look in to a weber carb conversion. If you can get them tuned right, you wont have to deal with most vacuum problems and any problems your stock carb might have. Jetting is key however.
Old Feb 20, 2014 | 06:40 PM
87yota599's Avatar
Right now I'm getting my carb rebuilt and I have my buddy's he let me borrow on right now and it makes it run worse then the other one. I know where your coming from with the weber carb but I'm going to try an see how it goes with my stock one.
Old Feb 20, 2014 | 06:55 PM
When you say its running worse what do you mean? Running too lean? Too rich? Bogging down? No bottom end power? No top end power?
Old Feb 20, 2014 | 07:07 PM
87yota599's Avatar
It's lugging on me until I step on it. And my carb that is getting rebuilt was too rich and we couldn't get it to run right with it on. It just didn't want to run.
Old Feb 20, 2014 | 07:44 PM
Dont narrow it straight down to the carb. You sure all cylinders are firing? Whether it be due to compression, spark or fuel? You could have a dead cylinder causing no bottom end power. have you checked the timing? Could also be a possibility. I would check timing with your buddies carb and make sure it's on point.
Old Feb 20, 2014 | 07:51 PM
87yota599's Avatar
The carb that I have on now is out of a 83 22r. It is sucking to much air if I can remember right. Some of the vacuum is all different then my stock one that I had on. And yeah just checked yesterday. Just replace wires, cap, rotor, plugs. Timing was on right before I changed the carb. But I will look again.
Old Feb 21, 2014 | 12:31 PM
Just give us an update once you get the rebuilt carb back on and we can work from there if your problem is not solved
Old Feb 24, 2014 | 09:16 PM
87yota599's Avatar
Hey guys I'm still waiting on my carb but it should be done soon. We ran a compression test today and it was around 175 in all 4 cylinders.
I'm still trying to figure out if I have the same head as a 22re.
coreyedwards7611
Jan 16, 2016 06:38 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
old87yota
Sep 9, 2015 12:39 PM
shalom
Sep 8, 2015 10:02 PM
skeeter0288
Aug 16, 2015 09:40 PM
