Leveling rear suspension..89 pickup
Old Jan 29, 2014 | 06:34 AM
Roark's Avatar
I've got an 89 Xtracab 4x4 with all stock suspension and 32/9.5/16s. The rear end sags a little, but predominantly to the passenger side. I assume it's due to the gas tank. In lieu of completely changing out the leafs with OME or 63 chevvies, like I plan on eventually, is there anything I can do to even out the back, but only the right side? Or will adding an AAL or something just make the right side taller than the left? I've never messed with the suspension, and don't exactly have the money to go experimenting..
Any help would be greatly appreciated!
Old Jan 29, 2014 | 09:47 AM
rattlewagon's Avatar
Add a leafs are cheap and will pick the back up a little. You could find another stock rear pack for cheap and make some bastard packs. It might be uneven- your springs are 25 years old. Anything you add to them will just be a band aid.
How long till you plan on replacing the springs?
Old Jan 29, 2014 | 07:27 PM
Gizler00's Avatar
x2 on this!! Listen to rattlewagon and get yourself some add a leafs or different packs.
I have used the AAL treatment to rear leaves with good results for a little while. Then they just end up doing the same thing. But if you are looking to save some money and band aid it for a while, that might be the way to go.
Old Jan 29, 2014 | 09:59 PM
Roark's Avatar
I won't be able to change out the rear springs permanently for a few years, at least. I'm just afraid of the possible effects a saggy butt will do to tires, mileage, babe-attracting, etc.. It just doesn't feel right having the truck look the way it is. I'll check out the local yards for some springs, and see what I can come up with.
Thank you guys, for the help. Much appreciated!
Old Jan 30, 2014 | 09:06 AM
4Crawler's Avatar
Various options discussed below:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ14
Old Jan 30, 2014 | 11:17 AM
Roark's Avatar
Originally Posted by 4Crawler
Thank you much for the link.. Super informative
Old Feb 4, 2014 | 07:27 PM
Trail-Outfitters's Avatar
Swap the springs in the rear from side to side. Might take care of your lean at least until you are ready to swap to another set.
Old Feb 4, 2014 | 08:33 PM
Roark's Avatar
Wouldn't that just move the lean to the opposite side?
Old Feb 5, 2014 | 07:22 AM
Allot of times when leafs start to sag if you swap them it will even out. Worth a shot since it's free! You will be moving the worn spring to the side with less weight and the good spring to the side with a little excess weight.
Old Feb 5, 2014 | 08:34 AM
highonpottery's Avatar
i'd also assume swapping the leafs might even it out, assuming the cause is the gas tank weight - but seriously, if you're even spending the time messing with it you might as well do it once and swap in replacements at that time. i'd see if you can get some used leafs off CL or at a yard, since that will be your cheapest option.
one thing to consider is whether or not you want to lift the rig. OME leafs only come in a 2" lift minimum height (over STOCK height). if you don't want to lift, then you might consider the used leafs, overload add-a-leafs, or even airbags or air shocks. Actually, airbags will give you the option to raise one side higher than the other if you want. Chevy leafs will take the most work to install correctly and depending on which ones you get you may end up sagging again unless you add blocks or really long shackles.
Good luck!
luke0927
Jul 2, 2015 10:49 AM
87blyota
Jul 1, 2015 05:26 PM
cchinny
Jun 25, 2015 08:11 PM
zytra
Jun 24, 2015 08:14 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
