Worth going from V6 S12W calipers to S13W?
Old Jan 9, 2014 | 06:42 PM
Ridgeracer12's Avatar
Hey guys, I tried searching for info comparing the S12W vs S13W calipers but I see most owners that switch to S14w's are coming from 4 cylinder calipers. I have an 89 4runner that has a leaky MC and Booster and thought if I was replacing those that it might be worth just switching everything over to a 2nd gen S13 setup.
My question to you guys is if you think the gains going from the S12 to the S13 is worth it. Budget isn't too much of an issue I just don't want to waste money on new calipers/rotors/pads if it isn't going to be a noticeable difference.
Thanks a lot!
Old Jan 10, 2014 | 06:52 PM
RustBucket's Avatar
I've wondered the same thing. I made the upgrade from 4cyl to SW12 and it is an improvement. I also put T100 wheel cylinders in the rear drums. I've contemplated the SW13 calipers but have not tried it yet.
Old Jan 10, 2014 | 08:37 PM
CJM's Avatar
CJM
Upgrade to the T100 rotors as well, they are slightly thicker and slightly larger.
Old Jan 11, 2014 | 05:18 AM
donomite49's Avatar
What are the sw13's from?
Old Jan 11, 2014 | 05:46 AM
RustBucket's Avatar
92+ 4runners and T100s. The earlier V6 runners had the S12W
Old Jan 11, 2014 | 12:25 PM
donomite49's Avatar
Thanks bucket, that means I should have the 13's. I scored a nice set of calipers and like new rotors from a 95 v6 runner at the local pull a part a few years ago.
Old Jan 12, 2014 | 09:28 AM
Thanks for the responses guys, from what I have read there isnt anything specifically showing it is worth the swap unless you needed to replace worn calipers and rotors anyways. Then in that case if you have then of course the s13w would be the choice... Im going to wait until then.
Jcrawl94
10
Oct 24, 2015 04:34 PM
traxxi2003
52
Jun 29, 2015 05:59 PM
MaK92-4RnR
7
Apr 4, 2012 04:13 PM
Bawlzdeep
Feb 4, 2012 05:05 AM
pattycakes77
May 23, 2010 03:47 PM
