What is best Head Gasket for 22re?
Replaced Head Gasket and it blew after 3,000 miles. Part was from ENGNBLDR and I think a FELPRO. My block coolant holes could be bored out from corrosion, I've read that this can be cause gasket to blow. Does anyone make a higher quality gasket? All copper? Oem?
I really doubt its from a faulty gasket, Millions of people use FelPro, anything can be defective but theyre not exactly a low quality gasket or anything....I would be looking more into another issue....WHAT made the first HG to blow in the first place? Coolant leak and made it overheat and blow? Did you make sure the head wasnt warped when you had the head off (assuming it overheated)? Which can cause any head gasket to blow easily since it doesnt have constant pressure on all spots. Has it overheated since it had the new HG put in? or any other related issues?
Original Head Gasket wasn't blown, replaced it when I did timing chain and cover. Also had head decked and rebuilt. Truck only overheated once 3k later, and that was due to coolant loss into combustion chambers. Did test and it was leaking at #1 cylinder.
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
