Pre 84 Trucks 1st gen pickups
l52 tranny sawp help
Old Dec 22, 2013 | 05:54 AM
rayshandyman's Avatar
My stepson was offroading and probably blew hjs clutch. Maybe the tranny does nkt work anymore. How do I diagnose the tranny to see if it still works.which other tranny is a direct swap to the l52.
Old Dec 24, 2013 | 06:00 AM
83's Avatar
83
Well, you're getting no response so I'll ask some questions...
What is it doing?
It's hard to diagnose a tranny if the clutch isn't even working. Short of pulling it and taking it apart. I understand that it would suck to do a clutch job and put the tranny back in, then realize it's bad too...and have to take it out again.
Direct swap as far as 5-speeds would be an L50 or L52. Same body style truck with a 5 speed. Otherwise you're looking at some modifications to make a later model tranny fit.
Old Dec 24, 2013 | 06:11 AM
I'll probably take it out and look at the clutch and probably put a new and Se what happens. What mods are needed to install later trannys
Old Dec 24, 2013 | 08:13 AM
83's Avatar
83
The search function here is your friend. Hundreds of people have had the same question answered.
In short, it depends on what transmission you're putting in. 84/85 had G-series trannies. Later models had W-series trannies.
Any transmission that came attached to a R-series engine (20R, 22R, 22RE) will bolt right up to any other R-series engine.
The issue is the length of the transmission. The G-series were longer, and I think the W-series are even longer still.
So basically: shorten the rear driveshaft. Lengthen the front driveshaft. Move the transmission crossmember back.
I have heard of someone having to pound the transmission tunnel in the bottom of the cab out a bit to make more space, also, but that doesn't seem to be part of the "conventional wisdom" as far as the mods needed to do the job.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
