285's rub in full turn
Old Feb 25, 2004 | 11:32 AM
Gringo's Avatar
What is the best way to get rid of the rubbing with the 285's in a full turn? I have heard you can use ATS A arms but was wondering if there is a cheaper solution?
Old Feb 25, 2004 | 11:34 AM
Fink's Avatar
Pound away on the fender linings and pinch weld is the easiest way I think...wait for others to respond but I think thats what they'll tell you to do.
Fink
Old Feb 25, 2004 | 11:35 AM
Jonathan's Avatar
Where are you rubbing? You might try a hammer to the pinch weld, because that is where a lot of guys rub. The ATS arms prevent rubbing on the arms themselves not necessarily anything in the wheel-well. If you have flares you might try trimming those as well.
Old Feb 25, 2004 | 12:45 PM
White SR5's Avatar
Another thing
Jonathon, what I did was take a look at where it actually was rubbing. On mine, it was rubbing on the mudflaps, so I just took a saw to them. Easy fix, and it really wasn't that much that I cut out to get the rubbing to stop. I also added 1" spacers. Just lock the steering wheel in full turn and then check out where it's hitting, then cut that part off.
Zach
Old Feb 25, 2004 | 12:47 PM
PoBoy's Avatar
Just get it over with and throw on a roger brown body lift You know you want to!
keisur's Avatar
I don't have that problem anymore. after you have them on there a while it goes away. Things get worn down or you end up beating the pinch weld.
Old Feb 25, 2004 | 03:31 PM
Gringo's Avatar
Thanks for the replies--this will be cheap!
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
