285's rub in full turn
What is the best way to get rid of the rubbing with the 285's in a full turn? I have heard you can use ATS A arms but was wondering if there is a cheaper solution?
Where are you rubbing? You might try a hammer to the pinch weld, because that is where a lot of guys rub. The ATS arms prevent rubbing on the arms themselves not necessarily anything in the wheel-well. If you have flares you might try trimming those as well.
Another thing
Jonathon, what I did was take a look at where it actually was rubbing. On mine, it was rubbing on the mudflaps, so I just took a saw to them. Easy fix, and it really wasn't that much that I cut out to get the rubbing to stop. I also added 1" spacers. Just lock the steering wheel in full turn and then check out where it's hitting, then cut that part off.
Zach
Zach
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
You know you want to!
