What wire tells the comp to fire the injectors
Old Nov 17, 2013 | 06:51 PM
BillysBuggy's Avatar
I have spark and and it will start with starting fluid, the fuel pump is running and you can hear the fuel recirculating into the tank. Its just wont start.
specs=87 22re, 1994 harness and ignition and to add to the fun 82 altenator with external voltage regulator.
Old Nov 17, 2013 | 10:38 PM
Terrys87's Avatar
Pins #10 and #20. Here is what I do to find non firing injectors.
Post #664>>>> https://www.yotatech.com/forums/f199...l#post51897320
Old Nov 18, 2013 | 04:45 AM
Thanks a bunch I'll try tonight again.
Old Nov 18, 2013 | 07:51 PM
So I connected the black wire from the ignition coil to the green with red stripe wire on the computer harness and it started.... then it ran for about a minute and then it started to idle up and down and just kept doing it until I unplugged the TPS then it just idled up. I reconnected it and started looking for air leaks by spraying starter fluid on the air in take tube connections, nothing changed so I took off the air filter and blocked off about 98% of the intake and it started idleing normal. The kicker is the air filter was extrememly filthy so I cleaned it(yesterday) so I messed with the tps, the air inlet deal, and the timing and got it to finally idle normal. What a headache. Now it starts and runs but I'm worried about how reliable it will be. Just wanted to give an update. I'm still going to get a noid light for future trouble shooting. Thanks again for the help!!!
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
88yodabasket
Jul 13, 2015 01:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
