Front right suspension blew...torsion bar or shock?
This is a 87 4runner sr5. All new suspension and bushings and KYB GR2 shocks. Was driving thru a dip heard a bang and front right suspension was sitting on bump stops. I thought I had blown a ball joint but structurally everything looks fine. Torsion bar looks fine but even if the shock was totally blown wouldn't bar still hold up truck some so it's not sitting on bumps?
If you broke a torsion bar your a arms would most likely be sitting on the bump stops.
If it was a shock it wouldn't be that low.
You can take them in and out with out the front moving much
If you bought one new torsion bar it would sit up a lot higher on that side and the suspension would act a lot different.
A new set would be the way to go.
SO I got to looking around and it looks like the big bolt at the rear of the bar backed out and the bar popped out losing tension. Does that sound right, like I said I dunno how the bars work. What is the best way to put the bar back to tension and tighten that right. Is there anything else I should check?
No you don't need anything special. As long as the bolt decent spin on the torsion key, just put a socket and breaker bar and crank on it. When I was messing with them I would pick a spot on the front of the frame and measure each side until they measured the same.
Then you know they are cranked about the same
Sway away is a brand that makes torsion bars Teuf.
They're the thickest available, I believe, so not sure I'd suggest them to the op for comfort, but they could be the cheapest new option. Other options are to check out your local Craigslist. I see used OEM on the SoCal Craigslists for $40-50 fairly often. 4x4connection.com also has the Old Man Emu torsion bars for $200+shipping! and they're 23 mm, I believe. Slightly thicker than stock, so just slightly stiffer.
