Removing LCA Bushing Metal from 2WD Pickup.
Old Oct 16, 2013 | 04:40 PM
Remled's Avatar
Alright I'm a bit stuck here. I've searched and searched and cant find a good solution for my problem. Any advice would be greatly appreciated.
94 Pickup 2WD and I'm in the process of replacing the lower control arm on the passenger side, along with the bushing. I was able to put together a great little tool to push the rubber out of the bushing with an impact drill (will post pics if anyone would like), but the metal hasnt budged.
Using a torch to burn it out seems a bit useless now that the rubber is out. Dont think that would accomplish anything. The other alternative I can think of is using an impact hammer/chisel to try and push the metal out from the edges, but that seems like I would end up causing quite a bit of damage to the frame.
Any ideas???
Old Oct 17, 2013 | 03:53 PM
Remled's Avatar
Don't know the policy on bumping my own thread here so I apologize ahead of time if it's frowned upon.
Anyone have ANY ideas here?
Am I going to cause damage to the frame if I use an impact chisel?
Old Oct 17, 2013 | 04:37 PM
millball's Avatar
Maybe you could weaken the shell by sawing it with a hacksaw blade held in vice-grips so very little chiseling would be needed.
Old Oct 17, 2013 | 04:50 PM
Remled's Avatar
Thanks for the advice. I did try getting in there with a sawzall, with no luck, but I'm guessing I need a better blade.
My impatience got the best of me and I went ahead and tried to hit the side without the lip with the impact chisel. No luck. I'm bending the metal up slightly, but I also was catching the frame I think.
STILL STUCK
Old Oct 17, 2013 | 07:32 PM
Zpd426's Avatar
Msg BlazeN8. I know he rebuilds those all the time. though they are the 4x4 arms. it may be a similar problem.
Old Oct 17, 2013 | 07:47 PM
Remled's Avatar
Thanks just sent BlazeN8 a PM.
Still open to any ideas. I'm desperate at this point....
Old Oct 17, 2013 | 07:53 PM
Xeo's Avatar
Xeo
What about using a air hammer too crush the sides of the sleeves? Then bopping it out with the air as well? Mind you im unfamiliar with the 2wd control arm bushings but if its like the 4wd it could work.
Old Oct 17, 2013 | 07:54 PM
Xeo's Avatar
Xeo
Oops didnt read the earlier post my bad disregard my idea lol
Old Oct 17, 2013 | 07:59 PM
Remled's Avatar
That was the original idea, but it looks like the hammer is going to cause just as much damage to the frame as the sides of sleeves.
Old Oct 17, 2013 | 08:01 PM
Xeo's Avatar
Xeo
You have any pics of how it looks? Maybe you could fit a ball joint remover in there? I'm just throwing ideas now.
Old Oct 17, 2013 | 08:12 PM
Remled's Avatar
Here's a few images of where I'm at. Last 2 are of the side without the lip (rear side), and first image is of the side with the lip. The side with the lip I have not touched with impact.
https://www.dropbox.com/sh/tn156aw056du4ay/MW8W7d-WEA#/
Old Oct 17, 2013 | 08:17 PM
Remled's Avatar
The ball joint remover I tried didnt fit around the frame. I could try the same tool I used to push out the rubber, but I havent been able to find anything (washer) that fits inside the area and still catches the metal casing.
Old Oct 18, 2013 | 03:08 AM
Xeo's Avatar
Xeo
Have you tried using a socket? If you haven't try using a socket with a extension you don't like and then take your air hammer and give'er on the extension. I hope you have a strong air hammer though. If not a big a$$ hammer might do it.
Sent from my moon base.
Old Oct 23, 2013 | 05:00 PM
BlazeN8's Avatar
I got your PM and link back yo this thread. I have not messed with 2WD so I am not familiar with the design. Check with Total Chaos or one of the other company's that make a kit for your truck.
glowz825
Jan 25, 2022 09:28 AM
Sep 4, 2015 09:27 AM
andrewtexas123
Jul 23, 2015 11:22 AM
msane99
Jul 17, 2015 10:13 AM
andrewtexas123
Jul 14, 2015 04:29 AM
