Few questions from a noobie
From: PNW, armpits of north Seattle... Lake Forest Park
Hey guys, I just traded my 96 honda civic for a 87 pickup ex cab. As she sits, it has a strong running 22r, 5-spd manual, however many lifts on new 35" tires and regeared to IM GUESSING 5.29's. Aftermarket bucket seats and probably the nicest I've ever sat my fat-behind in. I've owned a 93 4Runner and a 94 ex cab pickup... Not too knowledgeable on the 2nd gen pickups...
Few questions pertaining my rig...
1.) what is the "deck lamp" button to the left of my steering wheel?
2.) the heater works, but when in "off" position and only moved over one hash-mark, it blows as if it's on high, no change in fan speed. Is there a way to fix this and make it work like it's supposed to in each setting?
3.) has anyone ever installed a better/brighter/custom interior cab dome light? I'm hard of hearing and need sufficient light at times when it's dark to read my co-pilot's lips when driving
4.) is changing the shifter bushing similar to changing them in a 3rd gen pickup? I havent looked or had the time to do so hah
5.) haven't looked here either, but passenger door does not open from inside, only out. Could this be a simple rod that came loose or any suggestions as to what to look at?
6.)
6.)
Haven't finished or corrected the posting, my bad!!!
Regarding some light, has anyone installed a light to the REAR close to the seats as opposed to the front where it's located above the mirror?
6.) truck turns fine with the 35"s but I have some play and it pulls to the left. My steering stays "straight" but the wheel is turned right a bit, is there a way to fix this and have the steering tightened up and less slop or pulling?
Thanks for any help or advice
AND has anyone else ever had the temperature gauge never getting close to the 1/2 mark? Mine seems to stay below 1/4... Heater blows somewhat warm, not "hot" but comfortable warm. Simple heater hose/duct under the hood comes to mind but want to figure out the gauge as well.
The truck doesn't have an RPM gauge in the cluster. Would swapping an SR5 cluster be a direct swap and have RPM working or is this a matter of adding wirings? Thanks
6.)
6.)
3 yup lots of people have do a search for map light but theres lots of ways to do it
4 should be similar they could have the same tranny as a matter of fact
5 yes
1 is for a light should be behind the seat somewhere if the extra cabs came with them if not the beasel its in came outta a 4runner. 3 yup lots of people have do a search for map light but theres lots of ways to do it 4 should be similar they could have the same tranny as a matter of fact 5 yes
The transmission in this is a W56
I was just thinking of that... May have to check it out. Due for a tune up anyways. Plugs, wires, air/fuel filter, thermostat. All fluids flushed and topped off. Runs fine as it is, but would rather get it all the maintenance done with. Any suggestion for front/rear differentials and transmission/TC fluid?
when you pull it, it makes a sudden loud snap, and it's free... it can be rotated slightly at that point, then bolted back on.
do not overtighten the steering wheel nut!! read the factory spec.
slop could be anything... jack up the front end, have someone in the cab moving the wheel back and forth slightly, look for play.
6.)
6.)
2.) It's your fan control switch. Rip off the dash and pull out the actual switch, you'll most likely find that it has short circuited to only work on "off" and "high". Mine did the same thing. If that's not it, check the resister behind the glove box. But my money's on the switch.
3.) If you install the map light from an SR5, I recommend changing the bulbs out to 9 or 12 LED lights. I ordered these:
4.) Can't say.
5.) Take off the panel on the inside of the door. Most likely the rod slipped/broke off the handle. See FSM: http://personal.utulsa.edu/~nathan-b.../3frontdoo.pdf
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
