22re turbo motor wont run
Old Oct 7, 2013 | 02:38 PM
lilyoder_89's Avatar
Ok im looking at a 90's model yota an has a factory turbo set up put on it an will start an die start an die but if you use gas Or starting fluid it will run the guy said he checked everthing an still no luck does it have to have a differnt computer fpr it to run with the turbo
Old Oct 7, 2013 | 11:54 PM
wyoming9's Avatar
Red face
Has it ever run since this engine has been swapped in ??
Then it might be a bunch of parts cobbled together .
Yes you need the ECU and like any other swap the wiring harnesses to merge.
Sounds like you have your work cut out if this was not done.
You will need the EWD of vehicle you have plus the one for the vehicle the engine came from if it was a complete engine.
If you want it to look good if not I am sure given enough time you can build your own harness.
Old Oct 8, 2013 | 03:29 AM
dropzone's Avatar
Fossilized
Yep you need the correct ECU. They only offered the turbo in 86 and 87.
wonder if the guy only put the turbo/manifold etc on it.
I would continue to look elsewhere..
Old Oct 8, 2013 | 12:17 PM
Were could I find the right ECU ??
Old Oct 8, 2013 | 02:00 PM
wyoming9's Avatar
Red face
You would need the one for the 22rtec engine is it Auto or manual ??
As these engines are pretty rare it could be interesting.
You might be able to get a bad ECU and have it rebuilt.
Old Oct 8, 2013 | 03:15 PM
Were could I find one tho
Old Oct 9, 2013 | 03:56 PM
xXbrutalXcoreXx's Avatar
http://bit.ly/1anO529
Old Oct 10, 2013 | 12:12 AM
wyoming9's Avatar
Red face
That is to easy to make it more worth while and more rewarding one has to visit every yard in person .
Within 500 miles of where you live.
Blazing Sun Below zero temps. Blizzards
Only then can your search for a ECU be complete.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
karbin
Jul 5, 2015 11:37 PM
toyoda8488
Jul 5, 2015 10:18 PM
