Steering knuckles are bent :( Got ideas?
I just did a full Moog ball joint and tie rod job on my 92 4Runner. I took it to have it aligned the tech told me that my steering knuckles were bent. It's been steering a little funky since I did the work and I have the print out, so... I guess it's true. The dealer wants almost $400 each but I've seen pics around the interwebs of some aftermarket units and some even offer lift. I have some ball joint spacers on right now to balance out the Old Man Emu springs on the rear.
Does anyone have any experience with any of the aftermarket stuff? Any help would be appreciated as I don't want to trash my brand new tires.
Thanks in advance.
Thanks in advance.
Left= 4.5 degrees : factory specified range= 11.1-12.6
Right= 23 degrees : factory specified range= 11.1-12.6
Here in Michigan these trucks are a rare thing to find. I know of only one in a junk yard and it's been buried up to its bumper in dirt and mud for years. The tech told me that even using a puller (not a pickle fork, which would have been worse) can bend these. I don't know. I did use a puller. So if that's true and these are really that easy to bend then the ones off the junk yard truck could be bent as well.
I saw a knuckle on the web that had the lift built in but now I can't seem to find it.
Check this out.
https://www.yotatech.com/forums/f116...runner-273720/
and yes, they are hard to bend
maybe try another shop
Check this out.
http://www.digitalkungfoo.com/align.jpg
That's the printout. Yes, only lifted with the spacers. Nothing else other than the springs in the back.
jon.r
Jul 11, 2015 03:34 PM
